3560CG-8PC-S PoE as Power Injector, Cabability?
n.poongsawad
Has anyone has experience or infomation, how can I ensure that my new acquire 3560CG-8PC-S can do full power supply to all 8-units AP 2602E
3560CG-8PC-S
8 x 10/100/1000 Gigabit   Ethernet
8 PoE+
124W
2 x 1G copper or 2 x 1G   SFP
Thank you,
Nipat.p
2 Accepted Solutions
Florin Barhala
Level 6
Level 6
As read in the AP 2602E specs, each AP can consume up to 15.4W; this means a maximum value of 123.2W. It should work at once.
Power Draw
• AP2600: 12.95W
Note: When deployed using Power over Ethernet (PoE), the power drawn from the power sourcing equipment will be higher by some amount depending on the length of the interconnecting cable. This additional power may be as high as 2.45W, bringing the total system power draw (access point + cabling) to 15.4W.
Leo Laohoo
This will work.
You can power up to 8 APs requiring up to 15.4w PoE.
Florin Barhala
Level 6
Level 6
Power Draw
• AP2600: 12.95W
Leo Laohoo
This will work.
I'm doubt becauce used to know about issue on some kind of 2960s. Only half of ports support continuous PoE. In the other words we have to move to another chassis like 3750 PoE or 2960s with extra large PSU.
Did I miss understand on?
Half port PoE?  There's no such model on a 2960 except the 2960 LANLite.  This particular model only has 8 ports capable of 15.4w PoE.  The rest of the 16 ports are non-PoE.
3560CG-8PC is an 8-port switch and all 8 ports can supply a total of 124w PoE in all 8 ports.
