3700e and 3700p Antennas
Anyone know what antennas are supported with the 3700e and 3700p?
Everyone's tags (2)
Hall of Fame Super Silver
Re: 3700e and 3700p Antennas
The 3700 antennas can be found here or if you look up the release notes
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
The 3700p is stadium only and require the stadium antenna and I don't see that listed yet. Take a look at the 3500p as those are also stadium and uses only the stadium antennas.
-Scott
Shall we use single band
Shall we use single band antennas for 3700E AP's
Hall of Fame Super Gold
I believe the 3700p's antenna has a limit of 6 dBi maximum (similar to 3600p).  Only the 3500p can use the monster AIR-ANT25137NP.
just happened to trip across
just happened to trip across this thread looking for something else and figured it should be corrected (even if it's two years later) since if I just found it...others will too.
The 3702P is certified up to 13dBi and has it's own stadium antenna AIR-ANT2513P4M-N.
Thanks guys for your helpful replies.
Hi Guys,anyone know if Cisco
Hi Guys,
anyone know if Cisco are bringing out a high density antenna for the 3700P?  am being forced to implement the 3700 series AP and have some Theatres and high density areas to design to... 3500 not an option as they want .ac..
Mark
Found an antenna for the
Found an antenna for the 3700P
http://www.terra-wave.com/shop/font-colororangenewfont-80211nac-245-ghz-14-dbi-high-density-patch-antenna-with-nstyle-jack-connectors-p-2993.html
Mark
actually, that Terrawave
actually, that Terrawave antenna exceeds the allowed gain for the 3702P and should not be used.
Matt
The following antennas are
The following antennas are available for use with 3700e APs :
AIR-ANT2524DB-R – Dual-band (Black) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2524DW-R – Dual-band (White) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2524DG-R – Dual-band (Grey) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2535SDW-R – Dual band (short) dipole (4 required) – 3/5 dBi Dipole
AIR-ANT2524V4C-R – Dual-band Omni-directional (1 required) – 2/4 dBi Ceiling mount Omni use
AIR-ANT2544V4M-R– Dual-band Omni-directional (1 required) – 4/4 dBi Wall mount Omni use
AIR-ANT2566P4W-R– Dual band directional (1 required) – 6 dBi Patch wall mount use
The following antennas may be used with the AP 3600p and AP 3700p series.
Additionally, the AP 3700p has FCC approval for outdoor use with a higher gain antenna used for Stadium applications. Cisco AIR-ANT2513P4M-N is a Dual-band 13 dBi Patch antenna with “N” style connectors.
Please refer to the below link for more details :
www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html/index.html#pgfId-97040
Please refer to the link-http
http://www.cisco.com/c/en/us/products/collateral/wireless/3700-series-access-point/data_sheet_c78-729421.html
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html
4101
