3700E AP's with Single Band Antenna
Hi Team;
                       Is it possible to use a single band antenna(LXE-6000283ANTENNA) with 3700E Access Point or it will work only with dual band antenna.
Thanks & Regards
Sreejith R
1 REPLY
Hall of Fame Super Gold
You can but not supported by
You can but not supported by TAC and not recommended.
If you're going to use a single-band antenna, disable one of the two radios.
64
