3702i won't join 5508 controller. 3602i works.
I have over 100 new 3702i AP's and cannot get them to join.
used DHCP and static addresses and provided controller IP "capwap ap conroller ip address 10.23.180.20" nothing seems to work.
output from ap:
CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.23.180.20 peer_port: 5246
*May 23 15:51:05.003: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 23 15:51:05.011: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 23 15:51:05.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.23.180.20 peer_port: 5246
*May 23 15:51:05.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 23 15:51:05.471: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*May 23 15:51:05.471: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*May 23 15:51:05.471: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*May 23 15:51:06.003: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 23 15:51:06.031: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 23 15:51:06.039: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 23 15:51:06.047: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 23 15:51:07.067: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 23 15:51:08.067: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 23 15:51:10.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 23 15:51:10.471: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 23 15:51:10.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 23 15:51:11.471: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 23 15:51:11.499: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 23 15:51:12.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Well the AP has a mesh config
Well the AP has a mesh config, so you need to add the mac address to the mac filter list so the AP can join and then change the mode to local.  The code is the same.
-Scott
VIP Purple
Paste the Output of These
Paste the Output of These commands
Show Version from AP
Show sysinfo from WLC
AP88f0.319d.70d0#sh verCisco
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.2(4)JB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Sat 16-Nov-13 11:00 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
AP88f0.319d.70d0 uptime is 9 minutes
System image file is "flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-xx.152-4.JB1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702I-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FTX18177F9B
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.1.118
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:F0:31:9D:70:D0
Part Number                          : 73-15243-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC18147BL7
Top Assembly Part Number             : 068-05054-01
Top Assembly Serial Number           : FTX18177F9B
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702I-A-K9
Configuration register is 0xF
Controller
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB consol2
Build Type....................................... DATA + WPS
System Name...................................... North 5508
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.23.180.20
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 15 mins 47 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +29 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Burned-in MAC Address............................ 3C:08:F6:CC:C9:E0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 250
Thanks for the reply.
From what I can see this ios
From what I can see this ios  (AP3G2-K9W8-M), is for mesh AP's. Do I need to change this? Did Cisco send me AP's with the wrong os?
That is not wrong.... if you
That is not wrong.... if you issue a show ver on the other AP's, you should see the same.  The country code is correct and time is set right.  I would console into the AP and look at the output.
-Scott
VIP Purple
Hi,As scott told, Image is
As scott told, Image is correct.
Connect AP with console, reboot it and paste the entire bootup process here.
IOS Bootloader - Starting
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 48 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 13646848
flashfs[0]: Bytes available: 27511808
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 88:f0:31:b4:1a:3c
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-mx.152-4.JB1"...##########################
File "flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-mx.152-4.JB1" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-xx.152-4.JB1;flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-mx.152-4.JB1'
Loading "flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-xx.152-4.JB1"...######################################
File "flash:/ap3g2-k9w8-mx.152-4.JB1/ap3g2-k9w8-xx.152-4.JB1" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Initializing flashfs...
flashfs[3]: 48 files, 7 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 40900608
flashfs[3]: Bytes used: 13646848
flashfs[3]: Bytes available: 27253760
flashfs[3]: flashfs fsck took 10 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0  present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/Q2.bin
Radio1  present 8864 8000 0 80000000 80100000 4
POWER TABLE FILENAME = ram:/Q5.bin
Radio2 not present 0 0 0 0 0 8
export@cisco.com.
%Error opening flash:/ap3g2-rcvk9w8-mx/info (No such file or directory)cisco AIR-CAP3702I-A-K9 (PowerPC) processor (revision A0) wit
Processor board ID FTX18177F9K
2 802.11 Radios
Base ethernet MAC Address: 88:F0:31:B4:1A:3C
PCB Serial Number                    : FOC18157VZ3
Top Assembly Serial Number           : FTX18177F9K
% Please define a domain-name first.
flash:/mesh_start_cfg.txt: No such file or directoryThe filesystem containing the variables may not be initialized yet.
Spanning Tree protocol for Bridge Group 1 has not been configured.
Press RETURN to get started!
*Mar  1 00:00:14.775: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)
*Mar  1 00:00:14.779: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:15.231: Registering HW DTLS
APAVC: Initial WLAN Buffers Given to System is  2500
APAVC:  WlanPAKs 18174 RadioPaks  17566
*Mar  1 00:00:17.611: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:21.419: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:26.551: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:26.659: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:26.755: Wait until the stile protocol list is initialized.
*Mar  1 00:00:29.771: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:31.583: Starting Ethernet promiscuous mode
*Mar  1 00:00:31.583: Skipping Ethernet bridge initializaion
*Mar  1 00:00:31.587: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:31.971: Start STILE Activation
*Mar  1 00:00:39.755: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:39.755: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:40.003: Warning: Failed to run startup script
*Mar  1 00:00:40.015: %MESH-6-BVI_CREATED: Mesh BVI1 interface created
*Mar  1 00:00:42.043: %LINK-6-UPDOWN: Interface BVI1, changed state to downERROR: Failed to configure ethernet promiscuous mode. Int
erface Descriptor mismatch
*Mar  1 00:00:54.939: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-8)
*Mar  1 00:00:54.939: DPAA Initialization Complete
*Mar  1 00:00:54.939: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:55.143: No Mesh startup file found
*Mar  1 00:00:55.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:01:01.015: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:01:01.015: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Mar  1 00:01:01.939: APAVC: Succeeded to activate all the STILE protocols.
*Mar  1 00:01:01.939: APAVC: Registering with CFT
APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching  Original Buffer pool for system use
Pool-ReAtach: paks 18174 radio17566
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:01:04.879: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to uplwapp_crypto_init: MIC Present and Parsed Successful
ly
*Mar  1 00:01:05.011: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:01:05.091: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:01:05.091: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:05.107: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:01:05.107: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:01:05.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:06.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:01:07.087: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:01:08.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:15.091: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:01:19.039: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline power source
*Mar  1 00:01:20.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:21.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:21.311: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:22.103: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:01:22.311: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
Configuration of subinterfaces and main interface
within the same bridge group is not permitted
*Mar  1 00:02:10.059: %IPRT-6-STATICROUTESACROSSTOPO: Cannot install inter-topology static route 0.0.0.0/0 topology base on outgoing
 interface BVI1
*Mar  1 00:02:10.059: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:02:13.851: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:02:13.915: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.23.183.5, mask 255.255.252.0, hostname AP88f0.
31b4.1a3c
*Mar  1 00:02:13.915: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
Translating "CISCO-CAPWAP-CONTROLLER.sheboygan.k12.wi.us"...domain server (10.50.3.221)
*Mar  1 00:02:18.975: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:02:18.987: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:02:19.019: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:19.019: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:02:19.043: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:02:20.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:02:20.039: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:02:20.047: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:02:21.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:02:21.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:02:21.079: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:02:21.087: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down [OK]
*Mar  1 00:02:21.095: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:02:22.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:02:22.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:02:22.115: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:02:22.123: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:02:22.131: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:02:23.151: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:02:24.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:02:32.023: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 27 16:54:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.23.180.20 peer_port: 5246
*May 27 16:54:02.003: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:54:02.011: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:54:03.003: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:54:03.031: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:54:04.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:54:04.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.23.180.20 peer_port: 5246
*May 27 16:54:04.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 27 16:54:04.471: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*May 27 16:54:04.471: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*May 27 16:54:04.471: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*May 27 16:54:04.471: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.23.180.20
*May 27 16:54:04.475: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:54:04.483: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:54:05.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:54:05.503: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:54:06.503: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:54:09.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 27 16:54:09.471: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:54:09.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:54:10.471: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:54:10.499: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:54:11.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
DOT1Q vLAN encapsulation deleted, therefore interface removed from Bridge Group 1.
*May 27 16:55:07.063: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*May 27 16:55:07.075: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 27 16:55:07.103: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:55:08.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:55:08.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:55:08.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:55:09.059: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*May 27 16:55:14.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:55:14.559: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:55:14.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*May 27 16:55:27.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:55:27.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:55:28.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:55:28.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:55:29.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:55:47.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:55:47.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:55:48.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:55:48.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:55:49.039: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*May 27 16:55:49.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:56:07.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:56:07.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:56:08.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:56:08.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:56:09.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:56:10.035: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*May 27 16:56:10.035: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*May 27 16:56:10.035: %MESH-6-LINK_UPDOWN: Mesh station 88f0.31b4.1a3c link Down
*May 27 16:56:27.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:56:27.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:56:28.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:56:28.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:56:29.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:56:47.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:56:47.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:56:48.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:56:48.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:56:49.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:57:01.015: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*May 27 16:57:03.015: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*May 27 16:57:04.015: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*May 27 16:57:06.091: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 27 16:57:07.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:57:11.611: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:57:12.635: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:13.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:57:14.611: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*May 27 16:57:14.663: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.23.183.5, mask 255.255.252.0, hostname AP88f0.
31b4.1a3c
*May 27 16:57:14.663: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*May 27 16:57:19.723: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*May 27 16:57:19.739: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 27 16:57:19.763: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*May 27 16:57:19.767: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:20.739: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:57:20.767: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:57:20.775: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:57:21.795: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:22.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:57:29.763: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 27 16:57:30.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.23.180.20 peer_port: 5246
*May 27 16:57:30.003: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:57:30.011: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:57:31.003: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:57:31.031: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:32.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:57:32.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.23.180.20 peer_port: 5246
*May 27 16:57:32.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 27 16:57:32.467: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*May 27 16:57:32.467: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*May 27 16:57:32.467: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*May 27 16:57:32.467: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.23.180.20
*May 27 16:57:32.471: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:57:32.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:57:33.471: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:57:33.499: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:34.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 16:57:37.467: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.180.20
*May 27 16:57:37.471: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 16:57:37.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 16:57:38.471: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 16:57:38.499: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 16:57:39.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
-Scott
Here is how you do it.http:/
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1522-lightweight-outdoor-mesh-access-point/113678-wlan-mesh-config-ex.html#add
-Scott
I'm having the same issue I
I'm having the same issue I believe. The AP is booting up and trying to setup in a mesh mode when we are not configured for mesh mode on our 5508. Question I have is we don't have any MAC filters in place currently on our 5508 and I have 69 active APs that are in production. Would following the steps you suggest (i.e. adding a MAC filter for the AIR-CAP3702I) cause an implicit deny to all other MAC addresses and cause an outage to my 69 other APs and their clients? If so what is the work around for getting these APs that are booting up with mesh mode from the factory. I have over 30 to bring up and configure and they're all coming up in mesh mode instead of local. Is there any way to change this setting locally on the AP via CLI?
That was it. Thanks
That was it. Thanks
Change the mode to local mode
Change the mode to local mode and then Add the mac address to the mac filter list so the AP can join.
2556
