3850 MC connect with 3502 AP
hi all
i have truble with 3850MC with AP
this is the deployment
3850(MC)  169.254.1.254
3850(just switch)
3850(MC)<-----Trunk allowed all----->3850<------->3502AP
1. when AP conneted 3850(MC) directly that time working well.
2. But AP connected 3850(MC) through by 3850 then i have got some error.
here is the error
*Feb 26 10:31:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 169.254.1.254 peer_port: 5246
*Feb 26 10:31:45.229: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 169.254.1.254 peer_port: 5246
*Feb 26 10:31:45.229: %CAPWAP-5-SENDJOIN: sending Join Request to 169.254.1.254
., 1)26 10:32:03.380: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(UNKNOWN_MESSAGE_TYPE (5)
*Feb 26 10:32:03.380: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Feb 26 10:32:03.380: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 169.254.1.254:5246
*Feb 26 10:32:04.547: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
any help?
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Purple
Re: 3850 MC connect with 3502 AP
Yes it will work if you have 5760 WLC as MC and 3850 as MA and then you can connect AP to 3850.
Here is the link:
http://mrncciew.com/2013/12/14/3850ma-with-5760mc/
If you dont have 5760 then use asin case 1 : directly connect to MC(3850)
Don't forget to rate helpful posts
VIP Purple
APs must be directly connected to the 3850 for it to work in MA or MC mode. you have to directly connect AP to 3850 (not via transient switches)
thanks for the answer sandeepchoudhary21's
if you say so i know about the APs must be directly connected to the 3850.
APs connected with 3850 but not a 3850MC
i have another question.
APs conected 3850 but i didn't put any configuration for working MA
do i need to any configuration if i want make a 3850 MA mode?.
VIP Purple
Hi Youn,
as per my knowledge,
You need to connect on MC... After that, all APs that connect to a 3850, will terminate to that switch. The MC is like the WLC function.
Q. Does the Cisco Catalyst 3850 support indirectly connected access points?
A. No. The Cisco Catalyst 3850 switch will always terminate the CAPWAP   tunnel locally. Pass-through mode or indirectly connected access point   is not supported at this time.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/qa_c67-722110.html
Dont forget to rate helpful posts
thank you for the answer
as you can see
1.  3850(MC)--------APs    <-- at this time working without error
2. 3850(MC)------3850(MA)-----APs   <----- at this case get error message
here is my guess
1.in 2 case doesn't work. when i use MC. case 2 can be working with WLC5760.
2.if i have no WLC5760 I can use only Case 1.
do you think am i right?
VIP Purple
Here is the link:
Thank you very much!.
now i totally got this. your my hero!! Thank you so much!!
VIP Purple
Glad to help.
VIP Purple
Check this:
http://www.cisco.com/web/learning/le21/le39/docs/tdw_185_qa.pdf
Question: Do the APs need to be connected directly into 3850 or can the 3850 be used as a distri switch ?
which attaches to the AP?
Answer: yes 3850 only supports directly connected AP's
391
