Community Member
3850 questions
Had a few 3850 questions.
Can the 3850 also act as a controller with the IP base license? If true, would a controller this size be appropriate for a branch office rather than an enterprise?
If using the "Mobility Access" mode it is akin to the classic controller/thin AP archetecture?
"Mobility Controller" mode is making the 3850 the controller?
How does licensing work. Must you purchase a license per AP only if you are planning on using mobility Controller mode?
Must my 3850 have PoE+ in order to power the 3702i APs to use 802.11ac?
Also, I've read the data sheets but, they don't really go into much depth - especially about the wireless function. Anyone have any docs going into detail about the 3850 wireless capabilties?
Thanks.
Everyone's tags (1)
Hall of Fame Super Gold
Yes.  If you want to run 802.11ac on your 3702 then you need PoE+.  If you don't provide 20.0w PoE then the AP will operate but at a slower data rate.
VIP Purple
In simple terms, Converged
In simple terms, Converged Access deployment controller functionality split into two
MA - Terminate CAPWAP, keep client database entries
MC - RRM, Mobility, etc
By default 3850 is MA when you configure a wireless management interface on it. You need to have MC +MA (within the same switch stack or cetralized MC & distributed MAs) to get the system working. You need to have AP licence only on MC & not in MAs.
3700 AP to work you need to have IOS-XE 3.3.2 ( includes support for Z regulatory domain as well). 3850/3650 supports POE+
Below post should help you to get it starts
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Rasika
**** Pls rate all useful responses ****
Community Member
Rasika - Thanks for the link.
Rasika - Thanks for the link. I've started reading it - having gotten all the way through yet.
On a broader topic regarding the new 3850/wireless architecture; What is the recommended archecture? For example; is Cisco encouraging us to use the MC functionality on the 3850s at remote branches and small offices and a dedicated controller at main campus or is Cisco encouraging us to eventually replace all our controllers and go to a 3850 MC architecture.
Thank you
VIP Purple
Hi Patrick,Here is the Cisco
Hi Patrick,
Here is the Cisco recommendation.
Small Branch : 3850 switch stack act as a MC/MA  or one 3850 stack as MC & multiple other 3850 stacks as MA
Main Campus: 5760 or existing 5508 as MC at distribution layer & multiple 3850 stacks as MA at access layer.
For a large site, from the scalability point of view, you need to have centralised controller for MC function rather than run the MC functionality on a 3850.
Rasika
Community Member
Rasika, Thanks for the
Rasika,
Thanks for the response. So, in a large Main Campus best practice is to stick with the old controller. When 3850s are used at the Main Campus we should configure 3850s as MA. At small remote branches we should configure 3850s as MC.
When using the 3850 as an MC we will have to purchase licenses for access points, correct?
Thank you
VIP Purple
Hi Patrick,Yes, your
Hi Patrick,
Yes, your understanding is correct.smiley
When purchasing licence for 3850, it is only required for MC switch stack. No licence required for MAs. Lets say you have max 20APs at branch, then you can purchase single 3850 with 20 AP license & all other 3850 (if required) without any AP license.
Thanks for using the rating system as well.
Rasika
Community Member
Thanks Rasika - so, at the
Thanks Rasika - so, at the Main campus the 3850's selling point, other increased bandwidth, netflow and others, is it's ability to terminate the CAPWAP tunnel at the switch?
VIP Purple
Hi Patrick,Yes, 3850 is
Hi Patrick,
Yes, 3850 is performance enhanced switch & that should be a good replacment for any of the existing access layer switch models (wether you use WLC functionality or not)
Mainly 3850 in Converged access will give you the flexibility of treating wired & wireless traffic in same way for QoS & Security policy (since capwap terminate on MA at access layer, no more capwap tunnel back to your distribution layer WLC)
Also 802.11ac (1Gbps wireless) is another reason to terminate capwap at your access layer. Otherwise all these capwap goes back to 5508 & it will become the bottleneck (8Gbps max for all your APs)
Also improved roaming performance (within a SPG ) is another advantange
Netflow & other features are additional pluses of the CA.
Here is a very good presesntation of this CA architecture to understand the concept. This is from CiscoLive melbourne event held a week back.
Rasika
201
