3850 wireless AP config will not save
I have a 3850 switch stack and 1602i Lightweight access points. I setup the APs to join the switch via the DNS entry. When I access the 3850 GUI and go to the wireless controller to change the APs configs such as the names of the APs or their IPs, they change for a while they revert back to what they were within 1 minute.
Everyone's tags (1)
How to Configure a Static IP
How to Configure a Static IP Address on an Access Point
Configuring a Static IP Address on an Access Point (CLI)
SUMMARY STEPS
1.    enable
2.    ap name Cisco_AP static-ip ip-address static_ap_address netmask static_ip_netmask gateway static_ip_gateway
3.    enable
4.    configure terminal
5.    ap static-ip name-server nameserver_ip_address
6.    ap static-ip domain static_ip_domain
7.    end
8.    show ap name Cisco_AP config general
The AP CLI has no "Config
The AP CLI has no "Config Term" in enable mode
VIP Purple
HiThat's not the way you
That's not the way you configure AP name on 3850 (no need to go to config mode). Here is the command
3850#ap name <OLD_NAME> name <NEW_NAME>
Below is an example to show this.
3850-2#show ap summary
Number of APs: 1
Global AP User Name: Not configured
Global AP Dot1x User Name: Not configured
AP Name                 AP Model  Ethernet MAC    Radio MAC       State
L3502-1                 3502I     ccef.4872.0fc3  2c3f.382b.5260  Registered
3850-2#ap name L3502-1 name LAP1
Number of APs: 1
LAP1                 3502I     ccef.4872.0fc3  2c3f.382b.5260  Registered
Rasika
**** Pls rate all useful responses ****
VIP Purple
GUI of these controller is
GUI of these controller is not reliable. Try to use CLI & it will work all the time.
Below post give you some basic CLI commands including hostname change.
http://mrncciew.com/2013/09/29/getting-started-with-3850/
If you still prefer GUI, then go for the latest IOS-XE 3.3.2 version which has lots of GUI improvements
Rasika
I have set the AP name from
I have set the AP name from the 3850 CLI and Web GUI. In each case it sticks for about a minute and then reverts back to AP+MAC address. Same with the static IPs -- on that one I finially made a reservation on the DHCP server.
VIP Purple
What is the IOS-XE version of
What is the IOS-XE version of your 3850 ? I have no issues with 3.3.2 running for sometime & every time if I change an AP name it will retain.
Rasika
Switch Ports Model
Switch Ports Model              SW Version        SW Image              Mode
     1 56    WS-C3850-48P       03.03.02SE        cat3k_caa-universalk9 INSTALL
     2 56    WS-C3850-48P       03.03.02SE        cat3k_caa-universalk9 INSTALL
*    3 56    WS-C3850-48P       03.03.02SE        cat3k_caa-universalk9 INSTALL
     4 56    WS-C3850-48P       03.03.02SE        cat3k_caa-universalk9 INSTALL
VIP Purple
ok, you are running latest
ok, you are running latest image.
I do not have 1602 to test, I think it is better to log a TAC case (if you have support contract) what Cisco is saying about this.
Keep us posted if you get any update from them
Rasika
138
