3850 WLC - 5760 Anchor: Multiple Guest SSIDs issue
I have configured a 3850 Foreign WLC and a 5760 as anchor WLC in a DMZ behind an ASA FW. The Anchor Controller is configured to advertise 3 GUEST Wireless:
(INSIDE) ---- ASA FW (guest in interface) -------------------------- (Te1/0/1) 5760 ANCHOR (Te1/0/2) -------------------- L3 Link-------------------- (guest out interface) ASA FW ---- (OUTSIDE)
GUEST1: 10.9.65.0/24 – VLAN 11
GUEST2: 10.9.66.0/24 – VLAN 12
GUEST3: 10.9.67.0/24 – VLAN 13
Management VLAN 1: 10.8.252.1 (Anchor Management VLAN – Mobility)
The link between the WLC and the Guest OUT Interface on the ASA Firewall is a L3 Link, NOT a Trunk.
The 5760 WLC is also a DHCP server for the three client VLANs above. I have also configured 3 SVIs as default gateways for these VLANs:
Interface vlan 11 – 10.9.65.1
Interface vlan 12 – 10.9.66.1
Interface vlan 13 – 10.9.67.1
wgh-anchorwlc5760-primary#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.8.252.1      YES NVRAM  up                    up
Vlan11                 10.9.65.1       YES manual up                    up
Vlan12                 10.9.66.1       YES manual up                    up
Vlan13                 10.9.67.1       YES manual up                    up
GigabitEthernet0/0     10.8.252.85     YES NVRAM  down                  down
Te1/0/1                unassigned      YES unset  up                    up
Te1/0/2                10.8.253.1      YES NVRAM  up                    up
Capwap0                unassigned      YES unset  up                    up
If a client connects to GUEST1 SSID it gets an IP address in VLAN 11 and its default gateway is 10.9.65.1.
If a client connects to GUEST2 SSID it gets an IP address in VLAN 12 and its default gateway is 10.9.66.1.
If a client connects to GUEST3 SSID it gets an IP address in VLAN 13 and its default gateway is 10.9.67.1.
Mobility is UP and I can see clients connected to the Anchor WLC either in IPLEARN or WEBAUTH_PEND state. DHCP is working fine, clients get an IP and the right default gateway and DNS servers when connect, for example, to GUEST1.
anchorwlc5760-primary#show wireless client summary
Number of Local Clients : 3
MAC Address    AP Name                          WLAN State              Protocol
04f7.e482.b21c N/A                              2    IPLEARN            Mobile
bc3e.6d32.17f6 N/A                              2    IPLEARN            Mobile
a826.d5b3.5ae8 N/A                              2    WEBAUTH_PEND       Mobile
However, they are not able to ping the default gateway – SVI VLAN 11: 10.9.65.1, so I can not see any traffic leaving the Anchor WLC to continue with the Web Authentication Process (cwa) using ISE. I can see that the authorization policy (“unkown” and the URL to ISE) has been pushed to the clients but I am not redirected to ISE Web Authentication Portal when I open my web browser. I have done some captures on the FW interfaces but I cannot see any traffic coming from the clients.
I know that usually there is a Trunk (that allows client VLANs) between a WLC and L3 Switch when you configure multiples SSIDs and then configure the SVIs on the L3 Switch. However, I think this design with a L3 Link should work too because 5760 is a WLC+L3Switch.
My question is: Why clients are not able to ping their default gateway?
I hope it makes sense.
I appreciate any thoughts and help. Thanks in advance.
Joana.
Did you managed to find a
Did you managed to find a solution for this? How was it resolved?
Hi,I couldn't get it working
I couldn't get it working (I doubt if it is really possible). I had to add a switch between the 5760 Anchor Controller and the ASA Firewall:
(INSIDE) ---- ASA FW (guest in interface) -------------------------- (Te1/0/1) 5760 ANCHOR (Te1/0/2) -------------------- SWITCH-------------------- (guest out interface) ASA FW ---- (OUTSIDE)
The link between the 5760 and the Switch is configured as a Trunk and it allows the 3 Guest SSIDs (VLANs). The link between the Switch and the ASA FW is configured as a Layer 3 link. I also set up the default gateways for the 3 GUEST VLANs in the Switch (3 vlan interfaces) and the 5760 as DHCP Server.
I hope it helps.
Joana.
466
