Community Member
3850MC connect with 3502AP
hi all
im testing unified access solution in my office.
i installed 3850     1 32    WS-C3850-24P       03.03.00SE        cat3k_caa-universalk9 INSTALL
and i am trying to access ap with 3850 mc
but i couldn't figure out why didn't join in 3850
here is the error message in ap 3502
first time connected with 3850 but disable again
anybody  have any idea?
    =========================================ap message===================================
logging facility kern
% Invalid input detected at '^' marker.
Premature end of tar file
ERROR: Problem extracting files from archive.
archive download: takes 48 seconds
*Feb 21 10:36:14.425: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 169.254.1.254:5246
*Feb 21 10:36:14.428: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 21 10:36:14.494: %CAPWAP-3-ERRORLOG: capwap ifs:  read error or timeout
*Feb 21 10:36:14.595: capwap_image_proc: problem extracting tar file
examining image...
extracting info (284 bytes)
Image info:
    Version Suffix: k9w8-.152-4.JN
    Image Name: ap3g1-k9w8-mx.152-4.JN
    Version Directory: ap3g1-k9w8-mx.152-4.JN
    Ios Image Size: 594432
    Total Image Size: 10435072
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: AP3G1
    Wireless Switch Management Version: 10.1.100.0
Extracting files...
ap3g1-k9w8-mx.152-4.JN/ (directory) 0 (bytes)
extracting ap3g1-k9w8-mx.152-4.JN/Z2.bin (10504 bytes)
*Feb 21 10:36:24.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 169.254.1.254 peer_port: 5246
*Feb 21 10:36:24.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 21 10:36:24.349: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 169.254.1.254 peer_port: 5246
*Feb 21 10:36:24.349: %CAPWAP-5-SENDJOIN: sending Join Request to 169.254.1.254
*Feb .152-4.JN/file_hashes (701 bytes)
extracting ap3g1-k9w8-mx.152-4.JN/ap3g1-k9w8-mx.152-4.JN (121199 bytes)21 10:36:24.349: %CAPWAP-5-CHANGED: CAPWAP changed state to JOINperform archive download capwap:/ap3g1 tar file
*Feb 21 10:36:24.358: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Feb 21 10:36:24.364: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
*Feb 21 10:36:27.425: %DTLS-3-BAD_RECORD: Erroneous record received from 169.254.1.254: Duplicate (replayed) record
*Feb 21 10:37:12.425: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 169.254.1.254:5246
*Feb 21 10:37:12.428: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Feb 21 10:37:12.494: %CAPWAP-3-ERRORLOG: capwap ifs:  read error or timeout
*Feb 21 10:37:12.582: capwap_image_proc: problem extracting tar file
examining image...
Image info:
    Image Family: AP3G1
Extracting files...
*Feb 21 10:37:22.000: %C
extracting ap3g1-k9w8-mx.152-4.JN/file_hashes (701 bytes)
extracting ap3g1-k9w8-mx.152-4.JN/ap3g1-k9w8-mx.152-4.JN (121199 bytes)APWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 169.254.1.254 peer_port: 5246
*Feb 21 10:37:22.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 21 10:37:22.349: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 169.254.1.254 peer_port: 5246
*Feb 21 10:37:22.349: %CAPWAP-5-SENDJOIN: sending Join Request to 169.254.1.254
*Feb 21 10:37:22.349: %CAPWAP-5-CHANGED: CAPWAP changed state to JOINperform archive download capwap:/ap3g1 tar file
*Feb 21 10:37:22.358: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Feb 21 10:37:22.364: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
*Feb 21 10:37:25.303: %DTLS-3-BAD_RECORD: Erroneous record received from 169.254.1.254: Duplicate (replayed) record
1 ACCEPTED SOLUTION
VIP Purple
Re: 3850MC connect with 3502AP
Hi Youn,
See whether you have configured wireless management interface & AP put onto the same vlan configured switchport in 3850. Here is a sample config assuming vlan21 is wireless management.
wireless mobility controller
wireless management interface Vlan21
interface Vlan21
ip address 192.168.21.1 255.255.255.0
interface GigabitEthernet1/0/1
description WAP-01
switchport access vlan 21
switchport mode access
spanning-tree portfast
Refer this post for more details
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Rasika
*** Pls rate all useful responses ****
VIP Purple
did you conencted the AP directly to 3850 ?
Paste the output of these commands:
sh sysinfo from WLC
sh version from AP.
Reagrds
VIP Purple
Hi Youn,
interface Vlan21
description WAP-01
Rasika
336
