3G Module in Cisco 1841 Series
I was wondering if someone could help with a Wireless 3G antenna problem.
I currently have a Cisco 1841 Series router which came with a "Multiband Swivel-Mount Dipole Antenna". I have attached a Sim card to the module as explained in the manual and have unlocked the Sim card on the CLI prompt. I have also set up profile 1 (the default profile) to store the correct APN for the 3G network. Usually for 3G phones this is all that is needed and the rest is gathered by the Service Providers DNS etc and internet connectivity occurs. However once this is configured I try to ping http://www.google .com for example and it comes up with the error message “%Unrecognized host or address, or protocol not running”.
I can only assume by looking at the cellular configuration; shown below; (show cellular 0/1/0 all) that the profile 1 is not active and thus the router is not using it as a default route for internet. Does anyone know how I would go about setting up the 3G card as the default route out of the router, I have done the obvious.
Set an IP for the Fa interface, set one for the Cellular module and the used the command “ip default route <cellular ip>”
Hardware Information
Modem Firmware Version = H1_1_9_3MCAP C:/WS/
Modem Firmware built = 12/12/07
Hardware Version = 1.1
International Mobile Subscriber Identity (IMSI) = <IMSI Number>
International Mobile Equipment Identity (IMEI) = <IMEI Number>
Factory Serial Number (FSN) = <Factory Serial Number>
Modem Status = Online
Current Modem Temperature = 37 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = http://www.gibtele.com
Authentication = None
Username: , Password:
* - Default profile
Data Connection Information
--More-- ===========================
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = GIB, Network = GIBTEL
Mobile Country Code (MCC) = 266
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 2
Routing Area Code (RAC) = 2
Cell ID = 1041
Primary Scrambling Code = 73
PLMN Selection = Automatic
Registered PLMN = GIBTEL , Abbreviated = GIBTEL
Service Provider =
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Hall of Fame Super Gold
Re: 3G Module in Cisco 1841 Series
Have you gone through this documentation yet:
Configuration Examples for the 3G Wireless HWIC
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/3hwicdma.html#wp1216854
I have used this manual and I assume you are talking specifically about the "Configuration Examples for the 3G Wireless HWIC".
I seem to be more focused on using the first example as this looks more to what is needed; especially since 3G mobiles only need a APN url to operate properly.
I do not need a CHAP password so I select the option "ppp chap wait" as the router will not let me leave the password as nothing.
An Iphone for instance only needs a APN programmed into the phone and then the 3G turned on and all the other information is gathered via the APN.
Any ideas?
Hi Chris,
Kindly post the running configuration.
Btw, where you able to get an IP from the provider?
Please rate replies and mark question as "answered" if applicable.
i just wonder, the APN we put
i just wonder, the APN we put into phone, normally doesn't need http://
does it need in cisco router?
793
