4400 WLC with multiple VLAN & SSID
Have a sports event coming up and have a Cisco WLC 4400 that I want to deploy with multiple VLANS and SSID's.  I have a router with VLANs as such:
0     Management     192.168.1.x
10     Staff          192.168.10.x
20     Spare          192.168.20.x
30     Timing          192.168.30.x
40     Athletes     192.168.40.x
50     Public          192.168.50.x
The router has DHCP pools for each VLAN, and a trunk going to a 3560 POE switch.  I have ports 1-5 configured for VLAN 10-50 respectively, and plugging into them I can get an IP address and ping the router.
Now I need to expand this down to the WLC, so that I can deploy 12 LWAP's with SSID's of Staff, Timing, Athletes, and Public on their respective VLAN's.  How to configure this?  Is it better to have the WLC be the DHCP server or can I keep that on the router so that wired clients are also serviced?
Eric
Hall of Fame Super Silver
I would use the WLC dhcp only if I can't use any other dhcp.. Typically guest, I would use the WLC dhcp, but nothing else.
To get this to work, you need to connect the WLC into the switch on a trunk port.  Now if LAG is enabled on the WLC, you can connect all the WLC as an etherchannel.  You need to create a dynamic interface on the WLC with an ip address dedicated to the WLC dynamic interface.  So if your router has this:
0     Management     192.168.1.1
10     Staff          192.168.10.1
20     Spare          192.168.20.1
30     Timing          192.168.30.1
40     Athletes     192.168.40.1
50     Public          192.168.50.1
Your WLC dynamci interface can be this if not used:
0     Management     192.168.1.5
10     Staff          192.168.10.5
20     Spare          192.168.20.5
30     Timing          192.168.30.5
40     Athletes     192.168.40.5
50     Public          192.168.50.5
This link can help you understand
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/68100-wlan-controllers-vlans.html
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Thanks I followed the document and will test.  What about "Dynamic AP Management"?  It seems I can't turn that on.  Will I be OK without it?
Re: 4400 WLC with multiple VLAN & SSID
Leave the ap manager tied to the same subnet as the management. Don't create separate ap managers.
-Scott
OK so I followed the document and I have the WLC able to ping through all the VLAN's up through the 3560 switch then up to the router, and vice-versa.  I've plugged one AP into the Cisco switch, but it's not finding the WLC.  It's currently flashing green, yellow, red.  I have the port on the switch configured to be a trunk.  Do I need to do anything else?
Make sure the time is set properly on the WLC. Try putting the ap on the same subnet as the WLC managemt and make sure the Ap gets a DHCP address.
Post the output fr the ap console also from when you reboot the ap and letting it run for about 5 minutes.
-Scott
*Mar  1 00:00:06.069: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:06.079: *** CRASH_LOG = YES
Base Ethernet MAC address: 00:22:BD:18:99:41
*Mar  1 00:00:07.402: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.947: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:07.981: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 297 messages)
*Mar  1 00:00:09.033: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:10.111: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:10.151: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(18a)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 13:31 by prod_rel_team
*Mar  1 00:00:10.151: %SNMP-5-COLDSTART: SNMP agent on host AP0022.bd18.9941 is undergoing a cold start
*Mar  1 00:00:10.192: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:10.212: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:10.213: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:10.414: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:10.414: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:11.216: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:11.216: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:18.335: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.51, mask 255.255.255.0, hostname AP0022.bd18.9941
*Mar  1 00:00:29.038: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:00:29.192: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:29.218: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:31.815: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:31.833: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:31.849: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:32.817: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:32.833: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (208.67.222.222) (208.67.220.220)
*Mar  1 00:00:40.076: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Translating "CISCO-LWAPP-CONTROLLER"...domain server (208.67.222.222) (208.67.220.220)
*Mar  1 00:00:43.079: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:00:46.082: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Mar  1 00:01:31.816: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
VIP Purple
Did you created pool on router for APs to get IP???
If yes then did you configure the Option 43 ???
VIP Purple
AP should be configured as access ports.
Please try to keep AP and WLC on one subnet.
Here are other methods of having the ap find the WLC, but placing the ap on the WLC management subnet is the easiest. Once it joins, you can move it to another subnet.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
-Scott
I reset to LWAP to factory defaults, now I see an AP on the WLC summary screen, but no radios.  LWAP reports
lwapp_image_proc: unable to open tar file
VIP Purple
Paste the output of these 2 commands:
From WLC : sh sysinfo
From AP : sh version
Also paste the logs from AP
Here is the sy sysinfo from the WLC.  I can't seem to get into the AP.  Even though I've reset it the enable password isn't clear.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.0.148.0
RTOS Version..................................... Linux-2.6.10_mvl401
Bootloader Version............................... 4.0.219.0
Build Type....................................... DATA + WPS
System Name...................................... MWSC-PQI-WIFI
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 192.168.1.3
System Up Time................................... 0 days 0 hrs 53 mins 8 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +43 C
State of 802.11b Network......................... Enabled
--More-- or (q)uit
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:1B:53:64:33:20
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
VIP Purple
Also paste the sh version form AP.If you can not then can you tell me which version AP it is?? means the AP series like 11140 or 1242 or 1250 series???
As per your last logs from AP says that it is 1140 AP , is it right ?
Reagrds
Here we go
AP0022.bd18.9941>sh version
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 21-Nov-08 01:28 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
AP0022.bd18.9941 uptime is 14 minutes
System image file is "flash:/c1140-rcvk9w8-mx/c1140-r
*Mar  1 00:14:57.169: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !! cvk9w8-mx"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-A-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1328S55U
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:BD:18:99:41
Part Number                          : 73-11451-06
PCA Assembly Number                  : 800-30554-03
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13270K3B
Top Assembly Part Number             : 800-31273-01
Top Assembly Serial Number           : FTX1328S55U
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-A-K9
Configuration register is 0xF
AP0022.bd18.9941>
*Mar  1 00:15:07.169: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:15:17.169: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
VIP Purple
Means you have 1140 series AP.
You need minimum software version on WLC"5.2.157.0" for these AP to connect to WLC.
Please update to 7.0. seres to WLC and then try again.
Check here the compatibilty matrix :
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Hope it helps.
Dont forget to rate helpful posts and marked this question as answered, it may help others.
Hall of Fame Super Gold
Cr@p, that's one buggy software.
If you are able to download the firmware from the Cisco website, use 7.0.240.X.
AP not getting an IP address.
In enable mode, use this command "capwap ap ip address ".
I don't have access to the Cisco website unfortunately
The IP address error showed up because I had the WLC unplugged.  It's picking up an IP and registering now, just not downloading the tar file.
As Sandeep has pointed out, the WLC software does NOT support the AP you are using.  You need to upgrade the firmware of the WLC.
Thanks, guess I'm stuck.
Yeah... you should look at the WLC2504 with a 15 license or 25 license.  Those run pretty cheap and you can request the image you want and also you should be able to get support for 90 days.
AIR-CT2504-15-K9
2500 Series Wireless Controller for up to 15 Cisco access points
CON-SNT-CT2515
AIR-CT2504-25-K9
2500 Series Wireless Controller for up to 25 Cisco access points
CON-SNT-CT2525
Scott
-Scott
VIP Purple
You can ask your supplier or support partner to provide the 7.0.X series software for WLC. Surely then can!
Don't forget to rate helpful posts
Ok, have made some progress.  I now have the WLC upgraded to 6.0.182.0 and my AP's are registering and broadcasting SSID's.
Now the problem is I can get connected to the WLAN, but no DHCP or throughput.  My WLC can ping all the way to the router which has DHCP pools for all the VLAN's, and I've configured the "Primary DHCP Server" ip setting under Controller -> Interfaces, but still no IP address is assigned.  I've also removed this setting and setup a DHCP pool on the WLC itself, still nothing.  If I manually assign the IP on the client devices, I cannot ping the WLC interface or anything else.  What am I missing?
Eric
VIP Purple
did you enabled dhcp proxy on wlc ?
via GUI:
Controller->Advanced->DHCP
via the CLI:
Config dhcp proxy enable
Actually, I had to disable proxy and now it's working!
Eric
VIP Purple
If you areusing external dhcp server or dhcp bridging then you have to disable it configure the ip helper command.
Please rate helpful posts and mark this question as answered, it may help others.
553
