4402 controller high LAN utilization(600 Mbps)
Hi everybody,
I'm trying to configure Cisco 4402 series wireless lan controller on a proof of concept lab, but it's generating extremely high LAN utilization (around 600-700 Mbps) on its connected port to backbone switch. We are using GLC-T on 4402's port 0 for local connectivity. This traffic is starting even we do not use any access points in wireless network.
I configured controller 2 times after resetting to factory default, but the result is the same.
Best Regards
Ozan Oguz
CCIE#22559
Re: 4402 controller high LAN utilization(600 Mbps)
Have you tried span and capture that traffic?
problem has been solved by adding "switchport trunk allowed vlan x,y,z" command to the backbone switch.
OZan
223
