4402 to 3750G Lag/trunk
I have configured a 3750G with a trunk port to connect to my prod network. I have configured gi 1/0/1 and 2 as a channel group to connect to my 4402. After following all documentation that I have found, I still cannot connect to the 4402 throught the management interface.
here is the configs for the 3750G:
interface Port-channel1
switchport mode trunk
interface GigabitEthernet1/0/1
channel-group 1 mode on
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/24
description Lab Switch fa:0/6
speed 100
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan19
ip address 10.x.19.5 255.255.255.0
ip default-gateway 10.x.19.1
Here is the output from the 4402
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager LAG untagged 10.x.19.11 Static Yes No
management LAG untagged 10.x.19.10 Static No No
service-port N/A N/A 10.x.18.100 Static No No
virtual N/A N/A 1.1.1.1 Static No No
STP Admin Physical Physical Link Link Mcast
Pr Type Stat Mode Mode Status Status Trap Appliance POE
1 Normal Forw Enable 1000 Full 1000 Full Up Enable Enable N/A
2 Normal Forw Enable 1000 Full 1000 Full Up Enable Enable N/A
Any help would be greatly appreciated
Silver
Re: 4402 to 3750G Lag/trunk
You have a native VLAN mismatch. Your controller's management interface is "untagged", and your Port-Channel is configured (by default) to VLAN 1 as the native.
Since it's advised that you leave your management interface untagged, let's change your Port-Channel to support VLAN 19 as your native vlan. Perform the following configuration change:
int po1
switchport trunk native vlan 19
int range gig1/0/1 - 2
This should solve your problem. Good luck!
Hi, i'm encounter the same problem as above and managed to resolve it by configure the native vlan on the switch trunk to other vlan instead of default vlan 1, and it works!!!
But i'm still trying to figure out the logical of this...
Appreciates
Orochi
Silver
The thing you need to keep in mind is the concept of tagging. A trunk link adds a special tag to every packet that includes a VLAN number. The exception to this is the native VLAN, for which no tag is added. In other words, if a switchport receives an untagged packet, it reasonably assumes that this packet is on the native VLAN.
This is why it's so important to make sure that both ends have the same native VLAN. If they do not have the same native VLAN, traffic will literally change VLANs when going across the trunk. The access point, for example, might say "This packet is on VLAN 5, but since it's the native VLAN I won't tag it." The switch will receive it and say, "This is untagged, so it must be on the native VLAN, which is VLAN 1." Your packet just went from VLAN 5 to VLAN 1.
When configuring an access point for multiple VLANs, the GUI gives you an option of making the VLAN you configured the native. I think it's easy for a lot of people to check this when it's your "primary" VLAN, which seems reasonable to do. However, unless you configure this same VLAN to be native on the switchport to which the AP connects, you'll have problems as described above.
Hi Jeff,
My case was that both the AP-Manager and the Management interface were assigned to VLAN1, and on my catalyst switch trunk end, as you said, the native VLAN trunking was VLAN 1. So what you mean is, when the switch receive a frame from VLAN 1 and travel across the trunk, it's not tag. But my AP-manager and Management can only recognize the VLAN 1 tag frame, so this cause the problem that the connectivity cannot be establish isn't?
Another thing, i read some post said that the best practice for AP-Manager and Management interface to "Untagged", but couldn't find any articles about this. Just wonder is this a more efficient setup?
regards,
Orochi
Silver
That's correct. By setting them to VLAN 1, they had no way of knowing where an untagged packet was supposed to go. So they were likely dropping the untagged packets.
And yes, untagged is the best configuration for the management and AP manager interfaces.
Yep, get it works since i re-assigned the AP-Manager and Management int to "unassigned".
Thanks for help.Will rate u Man!!!
475
