5 GHz module in AIR-AP-1020 not work :)
I have Airospace AIR-AP-1020 access point in Site Survey Mode (jumper across both of the Site Survey header pins).
The 5 GHz radio not work :)
This is part of telnet sesion:
Atheros Access Point Rev 0.0.0.225
wlan0 -> 0x80fb3a30 (tNetTask): Invalid radio type in rrm
0x80fb3a30 (tNetTask): Invalid 802.11As Rate Information
Is this 5 Ghz radio damaged ?
This is "get config" information:
wlan0 revisions: mac 5.7 phy 4.2 analog 3.6
PCI Vendor ID: 0x168c, Device ID: 0x13
Sub Vendor ID: 0x168c, Sub Device ID: 0x13
AP software 0.0.0.225
Administrator@TEMPLAR:z:/gate/ath/ap/os/vxworks/target/proj/ap-ar5312
Jun 16 2005, 19:47:41
DEBUG
AP Cfg Rev: 2
Country Code: NA
Wlan State: Enabled
Radio Frequency: 5260 MHz (IEEE 52)
Wireless Mode: 802.11a
Auto Channel Select: Disabled
Data Rate: best
Antenna: 1
Login Username:
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: Airespace
SSID Suppress Mode: Disabled
System Name:
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
cfpStatus: Disabled
cfpPeriod: 10
cfpMaxDuration: 100
RTS/CTS Threshold: 2346
AIFS: 2
Minimum Contention Window: 15
IP Address: 192.168.0.50
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 0.0.0.0
SNTP/NTP Server IP Address:
Time Zone:
224
