5508 controller upgrade issue
After issue the transfer download start, I saw the debug log, but it never stop and the controller did not go to next step. What is the issue? I tested the tftp from another switch and it can fetch the file. I put the file under the home directory. When I select the tftp directory, I input "."
emWeb: Dec 03 14:11:15.078: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.079: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.109: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.110: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.146: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.160: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.162: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.295: Still waiting!  Status = 1
*emWeb: Dec 03 14:11:15.296: Still waiting!  Status = 1
thanks
Ray
3 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
It should be ""/" (no quotes).
VIP Purple
HI Raymod:
your parameter should be like this:
Example:
  • TFTP server IP Address—10.1.1.10
  • Maximum retries—10
  • Timeout—6
  • File Path—./
  • File Name—AIR-WLC5500-.........aes
Note: When you perform the upgrade from the GUI, for File Path, you can insert a dot (.) as long as the image is in the root directory of your TFTP server. This way, you do not have to enter the path were the image is saved
Hope it helps.
Re: 5508 controller upgrade issue
Raymond,
Can you please mark this thread as "Answered"?
Sent from Cisco Technical Support Nintendo App
VIP Purple
HI Raymod:
Example:
  • Timeout—6
  • File Path—./
Hope it helps.
Thank you guys for the reply. The upgrade completed finally. The size of the image is over 1G and the speed is the issue. I upgraded 2nd 5508 with ftp which is very fast at this time.
Cheers
Raymond,
198
