5508 WLC and 802.11n issue
I think I have read all disscussions about 5508's and 4402's and 802.11n issues on this support forum.  Maybe I missed something.
With the same laptop, on the production network, I cannot connect at 802.11n speeds, on the lab network I connect at 300mb/s
Attached are all my settings for the production Network.
Production Network;
5508 - 7.6.100.0
3502i
WPA2/AES w/802.1x
Lab Network;
4402 - 7.0.230.0
3502i
WPA2/AES w/PSK
I have reboot all all controllers and AP's.  Any suggestions?
Ryan
Hall of Fame Super Silver
Re: 5508 WLC and 802.11n issue
Create a new SSID in the production WLC for testing. Set this to 5ghz only with open authentication and make sure WMM is enabled on the QoS tab. Test with the client and see if the client does connect to the new open SSID on the 5ghz.
-Scott
Created new SSID, Open auth,  5Ghz only and it connects at 300.
Well that's shows you that it works. So now connect to your existing SSID and check to see if your connecting on the 2.4 or 5ghz and if your speed is over 54mbps. Also make sure WMM is enabled on that WLAN.
-Scott
I connected back to the production SSID/WLAN(all radios) and it connects at 802.11g, 54mb/s
Well then your WLAN setting is wrong somehow. You already tested with an open authentication so we know it works. Ale sure WMM is enabled and you only have WPA2/AES enabled not WPA/TKIP also or a mix.
-Scott
I know this is an old thread
I know this is an old thread but I had this same issue with windows 7 laptops and it was resolved by installing KB2848224.
802.11n works only with open authentication and wpa2/AES which you have already. WMM is also required to be enabled. On the 2.4ghz, the max you will see is 144mbps and on the 5ghz you will see up to 300mbps.
I want to make sure when you are testing is if you connect over 54mbps, that means you are connected with 802.11n rates. If your not getting past 54mbps, then there may be an issue with your configuration.
If so, post your show WLAN
-Scott
Post your show WLAN
Also make sure your connected to a 3502 or a 802.11n ap and not an ap that doesn't support 802.11n just in case.
-Scott
Ok I remove WLAN and added back. Still only connects at 54mb/s.
So currently, the only differece between WLAN's is that production is using 802.1x and AAA servers.  ALso the clients on production network are pushed a GPO that creates the Wireless Profile.
Ryan
Well, 802.1x will have nothing to do with that.  Maybe look at your GPO policy as you already tested that it works.
It's easier to verify that your config is fine by posting the show wlan
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
(Cisco Controller) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Wireless
Network Name (SSID).............................. Wireless
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Number of Active Clients......................... 18
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WLC1
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ vlan65
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
--More-- or (q)uit
    PMIPv6 NAI Type.............................. Hexadecimal
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
--More-- or (q)uit
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ x.x.x.x 1812
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
--More-- or (q)uit
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Enabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Disabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
--More-- or (q)uit
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Optional
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ NetflowAnalyzer
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
--More-- or (q)uit
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
You SSID settings are fine.... I would see what GPO they are pushing out. maybe they disable 802.11n.
Scott
-Scott
I think I found the issue.  I pushed out another GPO with almost exactly the same settings.  This time i unchecked FIPS compliace checkbox on the wireless profile.  Now im able to connect at 300mb/s.  Does this make sense??
I updated the production GPO with the change mentioned above and pushed that to my client and now im able to connect at at 802.11n speeds.
Thats good.... maybe there was a reason they made that change.
Scott
-Scott
Once i check the box for FIPS in my Lab Profile it drops to 54mb/s.  This is not good.
Well there is only one code v7.2 something that is FIPS compliant.  No other v7.x is FIPS compliant.
Scott
-Scott
930
