5508 WLC - SSID Availability Schedules
Is there a way to schedule the availability of SSIDs?  An example would be to restrict SSIDs to only be active during work hours.  This would be configured on a 5508 using 7.6 software.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
This only can be done with
This only can be done with with Prime Infrastructure or running a script maybe to login to the WLC and disabling the SSID.
Scott
-Scott
Scott
-Scott
We do have a Prime
We do have a Prime Infrastructure going into the site as well.  Is there any documentation on this process through Prime?
  Hi man,  This might help
You can search the forum also
You can search the forum also for other post similar to what you are trying.  That way you have different resources of info to use.
https://supportforums.cisco.com/discussion/11526451/schedule-ssid-availability
Scott
-Scott
262
