Ask the Expert- IoT Management
Community Member
5520 Wireless Controller Appliance Fan Noise
We have a 5520 WLC which is producing a very loud fan noise.
Is there a way from SSH or BIOS I can turn the speed down?
When logging in to the console there is no "show environment" command available which is something that has been suggested.
VIP Purple
Re: 5520 Wireless Controller Appliance Fan Noise
5520 wlc has this problem.
which version of SW you are running.. ?
check this poss: https://supportforums.cisco.com/t5/other-wireless-mobility-subjects/cisco-wlc-5520-periodically-making-huge-fan-sound/td-p/2920157
aslo chekc the bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux93468
Dont forget to rate helpful posts
Community Member
What command shows the version on a 5520?
Community Member
Software Version 8.1.102.0
Highlighted
VIP Purple
8.1.102.0 is already deffered from cisco. You must update the software version on WLC.
you can update to 8.2.166.0 and check again.
https://software.cisco.com/download/release.html?mdfid=286284738&softwareid=280926587&release=8.1.102.0
Hall of Fame Super Blue
That's a known bug, CSCux93468.
Everyone's tags (1)
582
