802.11g clients are not seeing the SSID
Hello Experts
I'm trying to setup a wireless 802.11n AP in mixed mode and 802.11g clients are not detecting the SSID's on few laptops and wireless mobile phones. Can some one provide me any pointer on how to fix it ?
Please find the configuration below, gig0/0 is configured as trunk and native vlan 220
Is there any link to find out on wireless lan drivers compatability ?
Building configuration...
Current configuration : 3139 bytes
version 12.4
no service pad
service password-encryption
hostname AP1
logging rate-limit console 9
enable secret 5 $1$xJD5$ym5rDY2gCjAPir9Y/y.PZ1
no aaa new-model
dot11 syslog
dot11 ssid Corporate
   vlan 220
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 09474B1909001B43595F
dot11 ssid Engineering
   vlan 221
   authentication open
   wpa-psk ascii 7 130E12021B09087B7977
dot11 ssid Guest
   vlan 222
   authentication open
   guest-mode
   wpa-psk ascii 7 10450C0915121E5A5E57
username Cisco password 7 062506324F41
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 220 mode ciphers aes-ccm
encryption vlan 221 mode ciphers aes-ccm
encryption vlan 222 mode ciphers aes-ccm
ssid Corporate
ssid Engineering
ssid Guest
antenna gain 0
station-role root
interface Dot11Radio0.220
encapsulation dot1Q 220 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.221
encapsulation dot1Q 221
no ip route-cache
bridge-group 221
bridge-group 221 subscriber-loop-control
bridge-group 221 block-unknown-source
no bridge-group 221 source-learning
no bridge-group 221 unicast-flooding
bridge-group 221 spanning-disabled
interface Dot11Radio0.222
encapsulation dot1Q 222
no ip route-cache
bridge-group 222
bridge-group 222 subscriber-loop-control
bridge-group 222 block-unknown-source
no bridge-group 222 source-learning
no bridge-group 222 unicast-flooding
bridge-group 222 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.220
no ip route-cache
bridge-group 1
interface GigabitEthernet0.221
no ip route-cache
bridge-group 221
interface GigabitEthernet0.222
no ip route-cache
bridge-group 222
interface BVI1
ip address 10.4.220.8 255.255.255.0
no ip route-cache
ip default-gateway 10.4.220.3
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
ine con 0
line vty 0 4
password sysadm01
login
line vty 5 15
password sysadm01
login
login local
end
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: 802.11g clients are not seeing the SSID
Your config looks okay. Maybe try to set the channel and power to see if that helps.
Sent from my iPhone
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Hall of Fame Super Gold
1.  Clients can't see the SSID because "broadcast SSID" is not enabled.  Your config is missing a statement:
mbssid
2.  You can't get 802.11n because interface interface Dot11Radio1 is in "shutdown".
327
