802.11N Frustration!
Thiago Cardoso
So i configured about 47 Access points 2 years ago
AIR-LAP1141N-A-K9
WLC 7.0.98
Its all working fine, using channel extension. Then my company bought a small office and i got 4
AIR-LAP1141N-A-K9  (awesome deal i pulled) then ok, plugged in, downloaded the image, DNS is config, all took about 10 minutes, AP up and running
NOw the FRUSTRATION!!!!
I have spent 5 HOURS! trying to create the CHANNEL EXTENSION! how did i do that? I remember something about 40Mhz but the controller wont allow me.
All APs says, current channel XX (Extension: XX)
1- disable the radio
2- select 40 Mhz custom
then magically it would assign a extension to the channel and work at 300mbps
I CANNOT DO THIS! HOW?!!! PLEASEEEEEEEEEEE HELP!!! I GIVE UP!!!!!!!!
the worst! I have google this for like 4 hours, i cant fix it, i got tired now im stuck need second set of eyes!
found this:
https://supportforums.cisco.com/thread/335229
no help at all!
12 Replies 12
Leo Laohoo
thanks man, but here's the catch
the 1141 doesnt have wireless A, it only does BGN some how it binds 2 20Mhz to create the 40Mhz using the extension channel. How? I'm looking for the answer and how to configure.
Thanks for replying quick though, but that I have read 4:40 minutes ago! LOL!
Vinay Saini said "
Jun 9, 2009 9:28 PM                             (in response to geetsingh22)
Re: client are not connected through 802.11n (AP 1140, WLC 5.2.178)
Hii ,
1. you need to configure WPA2+AES for the WLAN with WMM enabled on Qos page.
2. AFter doing this you will be able to connect at 144
3. For making 300 Mbps , Enable 40 Mhz operation for the AP
1. Go to AP radio setting page , disable radio
2. Make channel and power assignment as custom
3. Change the channel width to 40 Mhz
4. Enable radio
to make sure 40 mhz is enabled , go to AP console and issue "show controller d1"
you will see both primary and extended channel in use."
However the drop down only shows me 20MHZ. What the heck man! Maybe the controller is acting up and needs a reboot?
40 Mhz is found in the 802.11a settings.  802.11b will operate only in 20 Mhz.
Mea Culpa.  Didn't see that you have an 1141 (I thought you did a type-o).
If I select 802A none of the APs shows up. they are running with channel extension. Just dont know how i did it. I think I'll open a support case tomorrow, I'm in Germany it's almost 4AM!
Example is attached, you can see this is set to 20Mhz, but still with channel extension and this AP runs at 300Mpbs
I feel so stupid! i cant do it again!!!
Thiago Cardoso
come on, no one knows the answer? I even rebooted the controller (much needed reboot after 1 year running solid!)
Back in the days with 4.x you were able to set 40mhz on the 2.4ghz. Is that what you probably initially had back then? If so, maybe now the 40mhz stayed during the upgrade. But since you have 7.x, you will not have that feature with any new AP's
-Scott
Hello and Thank you for the reply. I have been running 7.098 for a while and 100% positive this has been configured with that version on some APs I bought last year or so too. I dont get why it works on all of the other Aps then.
Well they removed it from the newer 5.x and on. With that code setup for US country, you will not get that option.
Sent from my iPhone
-Scott
The recomendation is to configure 40Mhz for the 802.11a/n (5Ghz) band only, also im quite sure you cant enable it under the 802.11 B/G tab on the newer code releases as it would be unwise in 2.4Ghz band due to the lack of overlapping channels.
You can enable it either on a per AP or on a global basis, if you want to enable it on a global level see the attached screenshot:
Indeed. Even marketing pages now talk about a combined 444Mbps of throughput for a dual radio AP (300 MBps on 11a and 144 on b/g because of the lack of channel bonding)
