802.1x and static-wep-key conflict
When we enable Dynamic 802.1x in our WCS, we get a wep key prompt on devices connecting to the Access Points. This occurs without us setting a static wep key entry.
We think that this is caused by this config line appearing on the controllers:
wlan security static-wep-key encryption 5 104 <mode unknown> <passwd hidden> 1
If we then get clients to specify the SSID and 802.1x authentication, along with the requisite username/password credientials for the radius server, then a full authenticated 802.1x session can be succesfully established.
If we try to remove it via the console, the terminal doesn't return anything except a new line, and as soon as the interface is enabled again, the above line reappears in show running-config.
Nuking the config on the WCS - the SSID template, the Accounting server, the Authentication server, removing the entries from the access points then adding them back under a different name returns the same result.
Creating an entirely new set of templates, and applying it to a entirely untouched accesspoint also returns the same result.
This occurs on all devices I've got my hands on, which so far is:
iPhone, ipod touch gen 1 and gen2, OSX 10.6, win xp sp3, win vista, win 7, ubuntu 9.10 and finally a nokia n900.
Has anyone come across this and fixed this before?
Other background information that might help:
Versions/Configuration:
Wireless Control System
Version 5.0.56.2
Type:   Basic
Licensed APs:   250
Quantity of APs:        151
WLC's (4 of them - 2 in each WiSM)
1 WiSM is in a Catalyst 6506
1 WiSM is in a Catalyst 6509
Software Version of WiSM:    5.0.148.0
LAPs
Software Version         5.0.148.0
Boot Version    12.3.8.0
Inventory Information
AP Type         LWAPP
AP Model        AIR-LAP1131AG-N-K9
IOS Version     12.4(13d)JA
AP Certificate Type     Manufacture Installed
Unique Device Identifier(UDI)
Name    Cisco AP
Description     Cisco Wireless Access Point
Product Id      AIR-LAP1131AG-N-K9
Version Id      V01
APs converted to LAPs
AP Type         LWAPP
AP Model        AIR-AP1131AG-A-K9
This is the debug output of a failed attempt to connect to the wep key:
Thu Apr 29 12:31:09 2010: 00:1e:c2:b2:4e:17 802.1x 'txWhen' Timer expired for station 00:1e:c2:b2:4e:17
Thu Apr 29 12:31:09 2010: 00:1e:c2:b2:4e:17 dot1x - moving mobile 00:1e:c2:b2:4e:17 into Connecting state
Thu Apr 29 12:31:09 2010: 00:1e:c2:b2:4e:17 Sending EAP-Request/Identity to mobile 00:1e:c2:b2:4e:17 (EAP Id 19)
Thu Apr 29 12:31:09 2010: 00:1e:c2:b2:4e:17 Sending 802.11 EAPOL message  to mobile 00:1e:c2:b2:4e:17
Thu Apr 29 12:31:09 2010: 00000000: 01 00 00 2d 01 13 00 2d  01 00 6e 65 74 77 6f 72  ...-...-..networ
Thu Apr 29 12:31:09 2010: 00000010: 6b 69 64 3d 77 63 65 6c  2c 6e 61 73 69 64 3d 47  kid=wcel,nasid=G
Thu Apr 29 12:31:09 2010: 00000020: 47 2d 57 4c 43 2d 32 2c  70 6f 72 74 69 64 3d 32  G-WLC-2,portid=2
Thu Apr 29 12:31:09 2010: 00000030: 39                                                9
Thu Apr 29 12:31:11 2010: 00:1e:c2:b2:4e:17 Reached Max EAP-Identity Request retries (21) for STA 00:1e:c2:b2:4e:17
Thu Apr 29 12:31:11 2010: 00:1e:c2:b2:4e:17 dot1x - moving mobile 00:1e:c2:b2:4e:17 into Disconnected state
Thu Apr 29 12:31:11 2010: 00:1e:c2:b2:4e:17 Not sending EAP-Failure for STA 00:1e:c2:b2:4e:17
This, I understand, is the standard behavior for a failed static-wep-connection.
This is the output of show running-config for the wireless lan (snipped for bits relating to this ssid)
wlan create 5 wcel wcel
wlan interface 5 vlan 32
wlan aaa-override enable 5
wlan mfp infrastructure protection disable 5
wlan session-timeout 5 1800
wlan security wpa disable 5
wlan security 802.1X enable 5
wlan radius_server auth add 5 1
wlan radius_server acct add 5 1
wlan security wpa akm ft reassociation-time 20 5
wlan security wpa akm ft over-the-air enable 5
wlan security wpa akm ft over-the-ds enable 5
wlan dhcp_server 5 0.0.0.0 required required
wlan enable 5
1678
