Community Member
851W configuration problem
Hi all,
I'm trying to setup a 851W router as a wireless AP and I have no previous experience, so sorry in advance if I ask dumb questions! :) I have otherwise a lot of experience with Cisco but I just started using the wireless hardware.
Basically I have a SOHO setup with a DSL modem and static IPs. FastEthernet4 is the outside and the inside network (VLAN1) is 10.100.1.x/24. I used SDM to configure the wireless portion and I can actually connect using the laptop, but I do not get a DHCP address. I would like to obtain an address from the configured pool but it doesn't work and I'm not sure where the problem is, any idea? I don't understand the whole concept about wireless configuration and bridging, etc. If someone has some links that I could look at that would be great.
Also what security do you recommend WEP or WPA, and how I do I configure them?
Here's a copy of the config, let me know if you can help! Thanks
version 12.3
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname MJ851W
boot-start-marker
boot-end-marker
logging buffered 65536 debugging
enable secret
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.100.1.254
ip dhcp excluded-address 10.100.1.101 10.100.1.254
ip dhcp pool CLIENT
import all
network 10.100.1.0 255.255.255.0
default-router 10.100.1.254
netbios-name-server 10.3.4.31 10.1.4.31
dns-server 10.3.4.12 10.1.4.12
lease 0 2
no ip cef
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
no ip domain lookup
ip domain name cisco.com
ip ssh maxstartups 2
no ftp-server write-enable
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
ip address 204.54.26.140 255.255.255.0
ip inspect myfw out
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
no cdp enable
crypto map vpn
interface Dot11Radio0
no ip address
encryption key 1 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxxxx transmit-key
encryption mode wep mandatory
ssid WIFI
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no dot11 extension aironet
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.100.1.254 255.255.255.0
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 204.54.26.141
ip route 10.1.0.0 255.255.0.0 FastEthernet4
ip route 10.3.0.0 255.255.0.0 FastEthernet4
ip route 10.20.0.0 255.255.0.0 FastEthernet4
ip route 10.100.3.0 255.255.255.0 10.3.1.254
ip http server
ip http authentication local
ip http secure-server
ip http secure-port 10080
ip http secure-ciphersuite rc4-128-sha
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 102 interface FastEthernet4 overload
no cdp run
control-plane
banner motd ^C
line con 0
login local
no modem enable
transport preferred all
transport output all
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
1 REPLY
Re: 851W configuration problem
You need to create a BVI 1 interface, move the IP address and all the other internal commands from the VLAN 1 interface to it, and then add the VLAN 1 interface to bridge group 1.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
162
