857 Router Dot11Radio0 reset - problem
Hi all
I have just upgraded the IOS in a 857 Router to this:
ROUTER#sh version
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
but now I can't get the dot11radio 0 interface to come up. I just get a message saying the interface is reset and line protocol is down. I get this error message when I remove and re-insert the SSID -
ROUTER(config)#int dot11radio 0
ROUTER(config-if)#no ssid SSID
*Mar 1 04:04:24.655: %DOT11-4-NO_SSID: No SSID configured. Dot11Radio0 not started.
ROUTER(config-if)#ssid SSID
ROUTER(config-if)#
'Show run' shows the ssid is configured on the interface but the error message is saying that it doesn't have an ssid, even after a 'copy run start' and a 'reload'
I have spent hours on this and I can't find the problem. I have done numerous 'write erase' and 'reload' as well as re-installing the IOS twice.
Any advice would be very appreciated.
--- show output ---
ROUTER# sh ip int dot11Radio 0
Dot11Radio0 is reset, line protocol is down
Internet protocol processing disabled
ROUTER#sh int dot
ROUTER#sh int dot11Radio 0
Hardware is 802.11G Radio, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
Description: WLAN
MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/30 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
ROUTER#
--- show run summary ---
dot11 syslog
dot11 ssid SSID
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 ppppppppppp
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dot11Radio0
description WLAN
no ip address
encryption vlan 1 mode ciphers tkip
ssid SSID
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
infrastructure-client
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Bridged LAN and WLAN
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer1
description $OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1242
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap ppppppp
ppp chap refuse
ppp pap sent-username uuuuuuuuu password 0 ppppppp
interface BVI1
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip nat inside
1 REPLY
Re: 857 Router Dot11Radio0 reset - problem
Not to worry everyone. I have figured it out. I replaced the dot11radio 0 intface with this config
description WLAN
no ip address
ssid SSID
no cdp enable
no ip address
no shutdown
station-role root
and added in this config for the sub interface which was missing:
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
Thanks anyway.
889
