871 Not advertising SSID
When trying to view available wireless networks - I am not able to see "intheair" advertised. Am I missing anything? Thanks.
dot11 ssid intheair
vlan 1
authentication open
authentication key-management wpa
infrastructure-ssid optional
wpa-psk ascii 7 jabadahutcantina
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid intheair
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 871 Not advertising SSID
Hi Michael,
The command that controls the "Broadcast" of the SSID is "guest mode". Have a look;
guest-mode (SSID configuration mode)
Use the guest-mode SSID configuration mode command to configure the radio interface (for the specified SSID) to support guest mode. Use the no form of the command to disable the guest mode.
[no] guest-mode
The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with the access point. It also allows clients configured without a SSID to associate.
Examples
This example shows how to set the wireless LAN for the specified SSID into guest mode:
(config-if-ssid)# guest-mode
This example shows how to reset the guest-mode parameter to default values (no broadcast SSID):
(config-if-ssid)# no guest-mode
From this IOS Command doc;
http://www.cisco.com/en/US/products/hw/routers/ps272/products_technical_reference_chapter09186a008022e0e3.html#wp2641711
Hope this helps!
Rob
1 REPLY
Hi Michael,
[no] guest-mode
Examples
Hope this helps!
Rob
357
