Community Member
871W using WEP and LEAP
I have configured the 871W for WEP and LEAP, and the client is prompted for the Username and Password. But it is not authenticating. I have attached the config of the router and the debug radius authentication.
871Wireless#wr T
Building configuration...
aaa new-model
aaa group server radius rad-eap
server 172.16.11.254 auth-port 1812 acct-port 1813
aaa authentication login eap-methods group rad-eap
dot11 vlan-name Data vlan 11
dot11 ssid DATA
vlan 11
authentication open eap eap-methods
authentication network-eap eap-methods
guest-mode
ip dhcp excluded-address 172.16.11.1 172.16.11.49
ip dhcp excluded-address 172.16.11.101 172.16.11.254
ip dhcp pool Wi-Fi-Data
network 172.16.11.0 255.255.255.0
default-router 172.16.11.254
dns-server 198.207.23.58 199.172.192.3
bridge irb
interface FastEthernet0
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid DATA
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.11
encapsulation dot1Q 11
no cdp enable
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 spanning-disabled
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
interface BVI11
description *** Wireless Voice ***
ip address 172.16.11.254 255.255.255.0
radius-server local
nas 172.16.11.254 key xxx
user paul nthash xxx
radius-server host 172.16.11.254 auth-port 1812 acct-port 1813 key xxx
control-plane
bridge 11 protocol ieee
bridge 11 route ip
line con 0
line aux 0
line vty 0 4
1 REPLY
Gold
Re: 871W using WEP and LEAP
The one thing I noticed with your config is that the encryption statements don't include the vlan statements. You should have "encryption vlan 11 mode wep mandatory". You don't need to specify an encryption key. Since your doing dot1x the keys will be dynamically created.
213
