877w Communication Between Wireless Clients
I have a Cisco 877w (configuration shown below) and i am trying to use a Photo Transfer App on my iPhone4s and iPad3 which allows transfer of photos and videos between the devices using WiFi, the only thing is i cannot get my devices to communicate with each other and i suspect that this is to do with the configuration of my router as the app works perfectly using bluetooth but obviously a lot slower.  I cannot even ping the devices from my pc which is also on the same WiFi network.  Any suggestions on how i should tweak my config?
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Cisco_877W
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096 warnings
logging console critical
enable secret ***********
no aaa new-model
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
dot11 syslog
dot11 ssid W1F1-22
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii ***********
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool 1
   network 10.10.10.0 255.255.255.240
   default-router 10.10.10.1
   dns-server *************
   lease 0 12
ip cef
no ip bootp server
no ip domain lookup
username admin secret **************
archive
log config
hidekeys
ip tcp synwait-time 10
bridge irb
interface ATM0
description WAN
bandwidth 16000
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
shut
interface FastEthernet2
shut
interface FastEthernet3
shut
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid W1F1-22
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description INSIDE
no ip address
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer1
description FW_OUTSIDE
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname *****************
ppp chap password ***********
interface BVI1
description LAN
ip address 10.10.10.1 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat translation timeout 540
ip nat translation tcp-timeout 540
ip nat translation udp-timeout 540
ip nat inside source list 1 interface Dialer1 overload
logging trap debugging
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 15 permit ********
access-list 15 deny   any log
dialer-list 1 protocol ip permit
no cdp advertise-v2
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
transport preferred none
stopbits 1
line aux 0
exec-timeout 5 15
stopbits 1
line vty 0 4
access-class 15 in
exec-timeout 5 15
password *******
login
transport preferred telnet
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Hall of Fame Super Gold
Wrong forum as you have an Enterprise product. Should go in Wireless. You can move the post using the control panel on the right.
Silver
Hi Andy,
I have moved your post into the correct area for you.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
341
