881w strange behavior with iphones
Trying to pin down why my 2 iphones on my network are doing this. I have other wireless devices on here as well including a Tivo wireless G adapter, 2 laptops, a Sonos Play 5 and 2 ipads.
From the logs it looks like only the iphone is doing it which would point me towards a client issue but I would think the ipads would be doing the same thing since they are all running the latest ios 7.0.4.
It looks like they are leaving the BSS and also the auth is no longer valid. Does anyone have any ideas? Is this just showing my wife and I leaving the house for work so the wireless is no longer seeing the iphones?
Here is a snapshot of the logs:
*Mar 15 04:53:29.611: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   441e.a1f2.7bc7 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 04:53:43.675: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   7011.245c.dd4f Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 04:54:07.259: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   380f.4aef.53b1 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 04:54:17.551: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f0dc.e20d.c613 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 05:01:54.794: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 05:27:04.842: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 05:49:24.924: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 06:12:00.034: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 06:35:10.163: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 07:04:10.293: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 07:32:50.470: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 08:02:35.588: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 08:27:00.672: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 08:34:35.723: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 09:03:35.977: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 09:33:20.994: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 10:03:06.231: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 10:25:36.289: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 10:55:21.386: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 11:25:06.551: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 11:41:21.605: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 12:11:21.786: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 12:38:21.945: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 13:05:07.072: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 13:34:52.249: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 14:02:07.404: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 14:31:22.026: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0dc.e20d.c613 Reason: Sending station has left the BSS
*Mar 15 14:31:52.533: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 14:59:03.312: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f0dc.e20d.c613 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 14:59:14.992: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0dc.e20d.c613 Reason: Sending station has left the BSS
*Mar 15 14:59:30.052: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f0dc.e20d.c613 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 14:59:39.612: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0dc.e20d.c613 Reason: Sending station has left the BSS
*Mar 15 15:01:37.726: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 15:09:57.861: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f0dc.e20d.c613 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 15:10:20.905: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0dc.e20d.c613 Reason: Sending station has left the BSS
*Mar 15 15:11:03.597: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f0dc.e20d.c613 Associated KEY_MGMT[WPAv2 PSK]
*Mar 15 15:20:29.067: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0dc.e20d.c613 Reason: Previous authentication no longer valid
*Mar 15 15:25:32.827: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 15:38:25.175: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 15:38:35.943: %DOT11-7-AUTH_FAILED: Station 0026.bbda.69f3 Authentication failed
*Mar 15 15:40:58.054: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 380f.4aef.53b1 Reason: Previous authentication no longer valid
Hall of Fame Super Silver
Post your show run-config
Also, have you tried deleting the profile on the iphone and creating it again.  iOS 7.0.x seems to not be so good as I have to delete and create the profile every so often or reboot my iphone and ipad.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Are you meaning to just forgot the network and rejoin it or reset the network settings?
here is my show run on the ap:
ap#sh run
Building configuration...
Current configuration : 3706 bytes
! Last configuration change at 09:20:28 CST Tue Jan 21 2014
! NVRAM config last updated at 09:20:29 CST Tue Jan 21 2014
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
no logging console
no aaa new-model
clock timezone CST -6
clock save interval 8
dot11 syslog
dot11 vlan-name vlan1 vlan 1
dot11 ssid Blackbriar
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid optional
   wpa-psk ascii 7 (sanatized)
dot11 network-map
crypto pki trustpoint TP-self-signed-(sanatized)
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-(sanitized)
revocation-check none
rsakeypair TP-self-signed-(sanitized)
crypto pki certificate chain TP-self-signed-(sanitized)
certificate self-signed 01
  30820238 308201A1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 39363933 39383431 34301E17 0D303230 33303130 30343031
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3936 39333938
  34313430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C60768DA 1C309B68 8FDCD4CB 0C702F44 0A99F620 FA468F33 09E6A85F B012B6EF
  701DCFA6 0F8E50DA C0757FD5 F0D1E900 D3C8EF63 2E492EA2 603302D2 1B7A226B
  29746946 E31CC0EF 45DC2520 81FAE7C6 CE2E9BA2 3A0F2260 D3140BAB 4D3A28A8
  74F59542 D17B3B39 6E88B089 71089BB1 0B180C45 BBD0EFA9 A1C9ABD3 16F838DD
  02030100 01A36230 60300F06 03551D13 0101FF04 05300301 01FF300D 0603551D
  11040630 04820261 70301F06 03551D23 04183016 8014C4A6 67312ADE B3C75047
  7989018A 4739562B 3733301D 0603551D 0E041604 14C4A667 312ADEB3 C7504779
  89018A47 39562B37 33300D06 092A8648 86F70D01 01040500 03818100 2967F1CC
  C382BB62 27E158DE 173FE5F4 8EAC9E13 E3BA2A2A 018AA10B 071E1F7D 0028F2CB
  6C09139A 1AAD7CF3 95F8D251 F08C56EF 95ECD78D ABF137DD E5547E9C 2E3B27E4
  AA0E7C09 269B1843 AC1A3380 71714D51 45AADDFB 55BEF220 102AF409 82942B19
  D7B3FAD9 9CAC5343 79E52125 FC834958 18D9081B 7CA9E400 427E5D2A
  quit
username scott privilege 15 secret 5 (sanitized)
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
ssid Blackbriar
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 128 drop-packet
station-role root
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.40.0.111 255.255.255.0
no ip route-cache
ip default-gateway 10.40.0.1
ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
privilege level 15
line vty 0 4
privilege level 15
login local
transport input all
end
Remove this:
Scott
-Scott
Done, can you kindly explain what that was and why removing it will help?
Re: 881w strange behavior with iphones
I would try to explain it, but on the road:). Just search the command on Google and it will have links explaining what that is. That should help.
-Scott
187
