Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
881W wireless configuration help
Trying to configure this spare 881W but running into difficulties.. I've worked with some of the other Wireless ISR but this one looks way different. even where the interface Dot11Radio0 is access to be configured. I don't have Smartnet on this guy to reach out to TAC.
Then LAN side seems to work. I can plug a pc into port 3 and and an IP address and browse. Port FA4 to my ISP is working..
I really just want 2 vlan. Vlan 1 to be LAN , Vlan 2 to be for wireless and attached to one SSID. What do you  do with you get console over to the wlan-ap0 interface. The AP is running  ap801-k9w7-mx.124-10b.JA3 but I thought I saw some post about how important it is to upgrade or you can't even browse to it to use the GUI ?  I configured the ssid and but can't even see it broadcast yet.. I can't even find ap801xxxxxx software on the cisco site...
so far my configuration is
ip dhcp excluded-address 10.10.20.1 10.10.20.2
ip dhcp excluded-address 10.10.10.1 10.10.10.2
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   dns-server 8.8.8.8 4.2.2.2
   lease 0 2
ip dhcp pool vlan2
   import all
   network 10.10.20.0 255.255.255.248
   default-router 10.10.20.1
   lease 0 2
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Virtual-Template1
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 10.10.60.1 255.255.255.248
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
no ip address
ip nat inside
ip tcp adjust-mss 1442
bridge-group 2
interface BVI1
no ip address
interface BVI2
ip address 10.10.20.1 255.255.255.248
ip nat inside
ip nat inside source list vlan1 interface FastEthernet4 overload
ip nat inside source list vlan2 interface FastEthernet4 overload
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
ap side
no aaa new-model
dot11 ssid dluser
   vlan 1
   authentication open
   authentication shared
   guest-mode
dot11 ssid dluser1
   vlan 2
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid dluser
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
any help appreciated..
Mark
Re: 881W wireless configuration help
Hi Mark,
Is your ap's bvi interface picking up an ip address via dhcp?  Make sure you can ping it from the pc that you're trying to manage it from.
Your ssid's probably aren't showing up because you're trying to advertise multiple ssid's, so you'll need to configure mbssid on the ssid's and the dot0 interface.
Here's a good example:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap7-mbssid.html#wp1050468
hth
jeff
Brian, I'm not sure what you mean when your send is the bvi getting a dhcp IP address. On the router side, it's hard coded in. On the AP configuration side , the answer is yes, it picked it up..
I attempted earlier to limit myself to one ssid on the dot11 interface so to make it easier for troubleshooting but that didn't help. I really only need one ssid.  The strange thing is that the interface shows reset , down everytime I add the command 'guest-mode'..  if I removed, the dot11radio0 interface comes up..
I used trunking to create the backplane network over to the AP - have a few rolled out this way.
You get on the AP by typing "service-module wlan-ap 0 session"
Router#
interface wlan-ap0
ip unnumbered Vlan8
arp timeout 0
switchport trunk native vlan 8
switchport mode trunk
interface Vlan8
ip address 10.10.18.118 255.255.255.248
no ip redirects
no ip unreachables
ip inspect fw-insp in
ip tcp adjust-mss 1360
ap#
no ip address
no ip route-cache
interface GigabitEthernet0.1
encapsulation dot1Q 8 native
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
Brian, I dont' see anything on your config that deals with the wireless SSID portion. That's the main problem I'm having right now. I need to somehow be able to get the Dot11Radio0 configured with the right ssid and have the router assigned the dhcp address to the via a dhcp pool. I'm actually got the lan side of it up this way. I've created the vlan and the dhcp pool. If a pc plugged in to one of the port, it will connect and pick up one of the IP address. Just need to do this via the wireless portion , set to another vlan and created the SSID.
Here's my full wireless config
aaa new-model
aaa group server radius aaa-server
server-private 10.2.254.149 auth-port 1812 acct-port 1813 key ****
server-private 10.56.254.101 auth-port 1812 acct-port 1813 key ****
aaa authentication login eap_methods group aaa-server
aaa session-id common
dot11 syslog
dot11 ssid Quintiles
   vlan 8
   authentication open eap eap_methods
   authentication key-management wpa
   guest-mode
bridge irb
no ip address
no ip route-cache
no shut
encryption vlan 8 mode ciphers aes-ccm
broadcast-key vlan 8 change 600
ssid Quintiles
antenna gain 0
station-role root
interface Dot11Radio0.1
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
No ip http server
bridge 1 route ip
line con 0
privilege level 15
no activation-character
line vty 0 4
cns dhcp
end
Brian
I took some snippet of your config and made some changes  but while I can connect to the SSID of dluser1 ( same as before ) , I still  can't pick up a dhcp address on the wireless client. The dhcp pool sits on the router side.
here's my current config from both router and AP. I'm trying to use  vlan 1 as the wireless side..
ip dhcp pool vlan1
   import all
   lease 0 2
ip dhcp pool vlan2
   import all
   lease 0 2
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
interface Vlan1
ip address 10.10.1.1 255.255.255.248
ip nat inside
interface Vlan2
no ip address
ip nat inside
interface BVI1
no ip address
ip nat inside
interface BVI2
no ip address
ip nat inside
bridge 1 route ip
bridge 2 route ip
ap
dot11 ssid dluser1
   vlan 1
   authentication open
ssid dluser1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
bridge 1 route ip
Ok, I seem to have solved the problem.. I moved the scope to the AP side instead. then tied in the ip address on both BVI1 interface on the AP side and then vlan 1 on the router side.  Make sure that they are all on bridge group 1, radio interface and  including of course the SSID. Not even sure if I needed the sub interfaces but seem to be a nicer way to tie all together regardless. Thanks to all who responded.  Especially Brian.
Mark,
What do you mean when you say you moved the scope over? I am having the same problem with the wireless giving my laptop a dhcp address.
You mind posting your configs from the router and ap please?
thanks,
Sean
Sean, it's been a while but I think I mean when you switch between the AP and ther router portion of the configuration..
eventuanlly this is when I have done to get it to work..
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool vlan2
   import all
   network 10.10.20.0 255.255.255.0
   lease 0 2
ip dhcp pool vlan1
   import all
   network 10.10.10.0 255.255.255.0
   lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
username dlcisco privilege 15 secret xxxxx!
archive
log config
  hidekeys
bridge irb
duplex full
speed 100
duplex full
speed 100
ip address x.x.x.x 255.255.255.0
ip nat outside
duplex auto
speed auto
no ip address
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip access-group NO-INTRA-TRAFFIC in--- I'm just trying to block the 2 vlan from seeing each other.
ip nat inside
interface Vlan2
ip address 10.10.20.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list standard vlan1
permit 10.10.10.0 0.0.0.255
ip access-list standard vlan2
permit 10.10.20.0 0.0.0.255
ip access-list extended NO-INTRA-TRAFFIC
deny   ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip any any
access-list 23 permit 10.10.20.0 0.0.0.255
no cdp run
control-plane
^C
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
DLHOMErouter#
switch over to the router side..
Trying 10.10.10.1, 2002 ... Open
Building configuration...
Current configuration : 3716 bytes
version 12.4
no service pad
hostname ap.yourdomain.com.
enable secretxxx
no aaa new-model
no ip domain lookup
dot11 syslog
dot11 ssid LAN2
   vlan 2
   authentication open
   mbssid guest-mode
dot11 ssid dluser1
   vlan 1
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 0 testtest
username cisco privilege 15 secret xxx
username dlcisco privilege 15 secret xxx!
bridge irb
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
ssid LAN2
ssid dluser1
antenna gain 0
mbssid
basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m
station-role root
no ip route-cache
bridge-group 1
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.1
ip http server
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
end
ap.yourdomain.com.#
3977
