891fw Wireless Band Preference
I have an 891fw.  I have both radios working on a single SSID, the problem is that my client devices join the 2.4 Ghz radio by default.  If I shutdown the 2.4 Ghz interface, the devices will join the 5 Ghz radio.  How do I set the 5 Ghz radio as the "default?  I've posted the AP config below.  Thanks in advance.
version 12.4
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname ap
logging rate-limit console 9
no aaa new-model
clock timezone PACIFIC -8
clock summer-time PACIFIC recurring 1 Sun Mar 2:00 1 Sun Nov 2:00
ip domain name ***************
dot11 syslog
dot11 ssid SSIDSSIDSSID
   vlan 4
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 *******************************
crypto pki trustpoint TP-self-signed-3397509922
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3397509922
 revocation-check none
 rsakeypair TP-self-signed-3397509922
crypto pki certificate chain TP-self-signed-3397509922
 certificate self-signed 01
  quit
username ******************************
ip ssh version 2
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 4 mode ciphers aes-ccm tkip
 ssid SSIDSSIDSSID
 antenna gain 0
 channel least-congested 2412 2437 2462
 station-role root
interface Dot11Radio0.4
 encapsulation dot1Q 4 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid SSIDSSIDSSID
 antenna gain 0
 no dfs band block
 channel dfs
 station-role root
interface Dot11Radio1.4
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0
 description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
 no ip address
 no ip route-cache
interface GigabitEthernet0.4
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address 10.240.4.2 255.255.255.0
 no ip route-cache
ip default-gateway 10.240.4.1
no ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
alias exec s show run
line con 0
 logging synchronous
 login local
line vty 0 4
 login local
sntp logging
sntp server 10.240.4.1
end
  • Getting Started with Wireless
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
The wireless NIC card makes
The wireless NIC card makes that decision.
In some wireless NIC card, you can actually choose which radio to prioritize or use first.
542
