About Wireless Bridge Failover idea
I would like to set up 2 pair wireless bridge between two site . 1 pair wireless Bridge for normal use. another pair wireless Bridge is used  when another pair wireless bridge  link is fail
Building A
1 set Cisco Outdoor AP For Exising use (GB C AP)
1 set Cisco Outdoor AP For Back UP (GB D AP)
Building B
1 set Cisco Outdoor AP For Existing use (GB C AP)
Building A
All AP (GB C & GB D AP)connect to cisco 2960 switch
Building B
As same as Buiilding A  - All AP (GB C & GB D AP)connect to cisco 2960 switch
For this case, do you have what method for failover solution.
when GB C AP Link is down, data traffic can change to GB D Link to route.
Is it idea possible?
John
If you are able to keep both radios powered, you could setup an etherchannel on each side. Set the mode to your desired behavior active-backup.
This may provide you information about LACP if needed
http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/gigeth.html
VIP Purple
Re: About Wireless Bridge Failover idea
Hi John,
See whether below post helps you, where I have posted a sample configuration for load balance traffic across two wireless bridge links.
https://supportforums.cisco.com/message/4125800#4125800
I doubted you can configure etherchannel across two wireless bridge links. If you configure two independant bridges & pass same vlans then one end switch ports will be get blocked by STP.
Rasika
***** Pls rate all useful responses *****
That's a great point Rasika, I had in my head microwave links I've aggregated before.
Hall of Fame Super Silver
In the past I have deployed multiple bridge link on a layer 3 interface. You can also do like Rasika mentioned and set it up on layer two and define the spanning tree priority and load balance that way.
-Scott
376
