Access issue with WLC 2106
Hi, I have a WLC 2106 and 2 1250 APs connected to it. the controller works really good. all APs are associated.
The problem I have is that after a few days I cannot connect to the GUI interface or console.
I can still ping and trace the controller.
After i turn the controller off and back on it works again.
The internal temp show 56 C. Would this cause the problem ?
1 ACCEPTED SOLUTION
Re: Access issue with WLC 2106
thanks, apparently there is new version out. I'll update to 5.1 and see if that would fix the problem
161
