Access Point 1310 not Pinging
We are trying to connect two Access points 1310 (AIR-Br-1310G-A-K9-R)with each other but they are not pinging, pls suggest what could be reason.
Thanks & Regards
Silver
Re: Access Point 1310 not Pinging
These bridges require external antennas. What kind of antennas are you using, and how far away from each other are they?
If you can, please post the configs for the bridges so we can see if there's a configuration error.
Jeff
hi,
will Access points 1310 (AIR-BR-1310G-A-K9-R) ping if we keep both acess points side by side without antenna.
Shortly i will send you config. details.
Thanks & Regards
Hall of Fame Super Gold
Hi Deo,
Sure if the IP Addresses are configured correctly.
I hope you are leaving these AP's without any antennaes for long. There have been several cases of the radios failing because of the absence of antennaes.
176
