02-14-2017 01:21 AM - edited 07-05-2021 06:33 AM
I have to install a new setup with WLC 2504 and 4 1832I access points. I am doing ot with the help of videos and documents as am new to Wireless infra.
I am able to configure WLC and its i am able to login the gui mode. I tested with one access point its showing as not joined in Moniter-->statics-->Ap joine (no ethernet MAc showing) Kindly help make my setup up
WLC ip:-10.4.2.25
Vlan is :-100
Do i need to creat diffrent vlan for Access point
switch side :-wlc connected interface I made as trunk port and access points are access vlan 100
Solved! Go to Solution.
02-14-2017 06:09 AM
1. 1832 AP need minimum SW version on WLC is 8.1.122.0 and you have 7.6.120.0
Compatibility matrix: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
2. Your AP model is with Europe Regulatory domain:
Product/Model Number : AIR-AP1832I-E-K9
3. And you WLC is configured with US country code:
Configured Country............................... US - United States
Wireless compliance status: http://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Dont forget to rate helpful posts
02-14-2017 07:05 AM
Here you go:
https://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=280926587&release=7.4.150.0&relind=AVAILABLE&rellifecycle=MD&reltype=latest
*** download 8.2 or 8.3 version
02-14-2017 01:37 AM
paste the info:
sh sysinfo from WLC
sh version from AP
Also paste the bootup process from cisco AP console.
02-14-2017 05:40 AM
this what i am getting from Cisco AP when i connecte
[*01/01/2000 04:55:26.3299] CAPWAP State: DTLS Teardown
[*01/01/2000 04:55:30.9385] CAPWAP State: Discovery
[*01/01/2000 04:55:30.9385] Did not get log server settings from DHCP.
[*01/01/2000 04:55:41.0000] CAPWAP State: DTLS Setup
[*01/01/2000 04:55:41.3399] Bad certificate alert received from peer.
[*01/01/2000 04:55:41.3399] DTLS: Received packet caused DTLS to close connection
[*01/01/2000 04:55:41.3399] Lost connection to the controller, going to restart CAPWAP...
[*01/01/2000 04:55:41.3399] CAPWAP State: DTLS Teardown
[*01/01/2000 04:55:45.9385] CAPWAP State: Discovery
[*01/01/2000 04:55:45.9385] Did not get log server settings from DHCP.
02-14-2017 05:55 AM
paste the output of the above commands.
02-14-2017 06:14 AM
02-15-2017 11:54 PM
I would like change my WLC ip, vlan, I connected through CLI and need to change mangament ip to new kindly let me know how to do that.
02-15-2017 05:18 AM
Check the time on WLC!!!!
02-15-2017 05:27 AM
yes its showing wroung how to change that
02-15-2017 05:55 AM
under command > Set Time
02-14-2017 06:02 AM
02-14-2017 06:09 AM
02-14-2017 06:17 AM
Is the issue because if this ..?
If am upgrading the firmware will i get the device joined in WLC.
does my all other configurations are correct
02-14-2017 06:27 AM
first you need to upgrade the WLC software.
second, change the country to any European country on WLC. Then it will join.
02-14-2017 06:58 AM
I am unable to find out the Wlc software link
could you please help me by sharing the link
02-14-2017 07:05 AM
Here you go:
