Access point strange spectrum
Hello.
I have 5 APs 3602E. They are all enabled for a/b/g/n standards. When I check client statistics I can see different clients using 2.4nGHz protocol and 5nGHz protocol. But if I take radio analyzer I dont see any 5GHz networks available((( Moreover all Macbooks are connected using 2.4 GHz. I dont undestand why it is so((( I am confused: how many frequencies AP run? One (2.4 or 5GHz continously) or two (one per moment time). If two how to associate with AP using 5GHz? Please help me to undestand the situation.
Everyone's tags (1)
Hall of Fame Super Gold
Maybe your "analyzer" only
Maybe your "analyzer" only has 802.11b radio enabled or your wireless client only has 802.11b radio (and no 802.11a radio).
Hall of Fame Super Silver
You should be able to see on
You should be able to see on the WLC GUI if the 802.11a radios are enabled or not. You can see this on the main GUI page. You can also look at the
show advanced 802.11a txpower
this command will show you the 5ghz setting
-Scott
Silver
As mentioned by Scott and Leo
As mentioned by Scott and Leo you need to check the 5GHz band is enabled and analyzer monitoring freq. or end point supported radio.
Bronze
Hi,Make sure your analyzer
Make sure your analyzer wireless card support both bands 2.4GHz and 5GHz
and 2nd thing i might be possible the mac book which you are using that only works on 2.4GHz band.
102
