09-01-2013 06:49 AM - edited 07-04-2021 12:44 AM
It's my understanding that APs can join 3850s if and only if the APs are directly connected to ports on the 3850 next generation device.
Can someone point me to where this is explained?
Solved! Go to Solution.
09-08-2013 07:01 PM
Just to add, FlexConnect isn't part of converged access as the AP's terminate directly to the 3850's so there is no need for FlexConnect.
09-01-2013 07:25 AM
Well you need to make sure the 3850 is also a MC and has license.
09-01-2013 08:52 AM
Scott, Can you point me to where it's documented that the APs need to be connected directly to one of the ports off that switch?
09-01-2013 08:57 AM
Here is configuring mobility controller
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/mobility/configuration_guide/b_mobility_32se_3850_cg_chapter_01000.html#d4955e252a1635
05-09-2015 10:17 AM
is there any update now to this problem? I see that this post is 2 years old. is there any development after this? i have aironet 2600 CAPs scattered all over a building that am planning to connect to LAN BASE 3850 PoE switches and i have 3850 IP base as core switch to which the 3850 LAN base switches will be connected [back bone connection]. Will it b possible to make MC work in this scenario now? The AP licenses are installed on the core switch with the IP base feature.
05-09-2015 11:49 AM
In your case if all AP connect to a 3850 (MA), then they can register to it using licence available on 3850 as MC.
Rasika
05-09-2015 03:03 PM
Thank you Rasika, but am still not clear: the LAN Base 3850 PoE switch has MA by default? and access points connected to this can register onto the IP base 3850 switch which is acting as core switch and on which the AP licenses are installed? i.e. pass through is possible?
05-09-2015 03:23 PM
In converged Access, License will be on MC can be anywhere in your network. Once AP connected to MA 3850 at your access layer, it will get license from MC & register that AP to MA.
You can refer this post, in that I have used 5760 as MC, but in your case it will be another 3850 switch in MC role.
http://mrncciew.com/2013/12/14/3850ma-with-5760mc/
AP passthrough is different where you can connect AP to 3850 (any vlan other than wireless management vlan on that switch). In that case AP won't register to 3850, you can point it to any centralized controller (2504,5500 or even 5760) & register those to that controller. This is useful when you have AP models that is not supported in IOS-XE platforms, but still you want to connect those into those switches & register to a supported controller
let us know any further queries.
Rasika
*** Pls rate all useful responses ***
05-09-2015 09:56 PM
Thank you for this response. with passthrough future that means I can use a mix of 2960 series and 3850 series switches as both support location awareness and mobility i.e. give borderless experience.
regarding your comment on whether the LAN base image of 3850 supports MA role or not, I have been checking and couldn't find definitive answer. The info I got say summarily that the LAN base image doesn't support Wireless Controller but doesn't mention MA support separately. for price sake I would go for the LAN base image, if this MA support can be confirmed by anyone.
http://www.router-switch.com/ws-c3850-24p-l-p-5214.html
05-10-2015 03:04 AM
If you have LAN base 3850, try this
wireless management interface vlan x wireless mobility controller ip x.x.x.x
If these two command accepts without any problem, then it should work as MA. But to be 100% I would configure MC as well & plug an AP to MA & see if that register.
Here is how you configure normal 3850 as MC
wireless mobility controller wr reload ! wireless management interface vlan X wireless mobility controller peer-group ABC wireless mobility controller peer-group ABC member ip <MA_Wireless_Mgt_IP>
Rasika
05-10-2015 06:46 AM
I actually have two ipbase 3850 non-poe switch which will be stacked and serve as core switch on to which the AP licenses will be copied. And the plan was to connect the APs to 2960 PoE switch which i have them already, with this not possible to make it work,
a. I need to order another 3850 PoE IPbase or Lan base switch to connect the APs to
b. get a refund of the AP licenses and buy AIR-CT2504-50-K9. The AP licenses have not yet been used, i.e. have not yet been copied to the core switch.
What do you think is the return policy of the cisco? a bit out context question!
thanks!
05-10-2015 02:44 PM
I think option (b) is the easiest way.
In fact there is a special promotion when you buy two APs (3702,2702 or 1702) you will get 2504 with 25 AP license almost free of cost. Here are the part numbers for those promotions
AIR-AP3702I-UX-WLC
AIR-AP2702I-UX-WLC
AIR-AP1702I-A-WLC <- pick the correct regulatory domain AP model as per your country
Rasika
*** Pls rate all useful responses ****
05-09-2015 08:35 PM
I overlooked "lanbase" image component.
With that image, I do not think you can have MA role. You need to have min IPBase in order to the configuration given in the below post.
Rasika
09-01-2013 08:58 AM
Might also want to review this
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/white_paper_c11-726107.html
09-01-2013 12:02 PM
Scott,
I'm not sure why you included the link (Mobility Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3850 Switches))
Is this perhaps a way for Access Points that are not directly connected to the 3850 to join the Wirless Lan Controller portion of the switch?
