Aeronet 340 Access Point and Lightning Strike
Would appreciate some advice. Access point no longer shows any indication of receiving power. Could AC adapter only be fried or is the whole unit likely a goner? If the former, how best can I get a new adapter to try? If the latter, is it worth sending in for service? I do not have a service contract. Thank you!
Re: Aeronet 340 Access Point and Lightning Strike
You could check if the AC adaptor is woring with a volt meter. the output of the AC adaptor is 48 Volts DC.
If you need a the AP350 AC adapter I could send you one for . send me a reply and I 'll give you the details.
You are correct. No signal using the volt meter. Should have thought of that. This p/n is 430-004852. Please provide replacement details. Many thanks!
Brian Walton
brwalton@earthlink.net
Does anyone have a AP 340 AC adapter or know from where I can get one? The previous replyer here only has AP 350 adapters and says they are not interchangeable. I would appreciate anyone's help to avoid having to purchase an entire new AP. Thank you!
You can check out the p/n:AIR-PWR4855 for the AP340 universal AC adapter. Not sure if any refurbish co. has any stock for that, but it is worth a try.
Don't think so that you will want to deal with a company in Singapore that I know of that have that part.
Cheers
Thank you, k-poh. Refurb companies are a good idea. I am checking there.
160
