AES-CCMP Cipher is not supported with WPA Version 1
I have Cisco AP1142N autonomous that already working with this configuration:
dot11 ssid ExampleSSID
   vlan 998
   authentication open
   authentication key-management wpa version 1
   mbssid guest-mode
   wpa-psk ascii 7 045802150C2E1D1C5A4D
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 998 mode ciphers tkip
ssid ExampleSSID
antenna gain 0
mbssid
station-role root
When I try to change the vlan 998 encryption to AES with input "encryption vlan 998 mode ciphers aes-ccm" in interface Dot11Radio0, I keep getting this error message:
"AES-CCMP Cipher is not supported with WPA Version 1"
My linksys AP and even my chinese AP can manage WPA version 1 with AES. I really don't understand why the Cisco 1142 cannot. Is there any way that I can configure this Cisco AP1142N autonomous with WPA1-AES ?
Thank You.
Bronze
Re: AES-CCMP Cipher is not supported with WPA Version 1
Hi ,
Remember that any brand of access point will have its own encryption combinations to use and to which method to link them, but this may or may not work if the wireless clients supports it or not and also since the wireless client cannot do 2 encryption methods at the same time.
The thing is that to grantee compatibility between different brands of access points and wireless clients the IEEE stated that if you work with WPA version 1 we will use the cipher of TKIP and if you want to work with WPA version 2 we will use the cipher of AES-CCM.
Since are access points are compliant with the IEEE this is way you are getting an error message that does not allow you to configure WPA version 1 with AES-CCMP.
Also as a side not for N data rates to work on the 1140 N access point you will need to have no encryption configured or only WPA version 2 with AES-CCM since as per the N standard only WPA version 2 with AES-CCM supports N data rates.
If you would like to use different encryption methods, then the correct configurtaion would be to configure VLANs on the AP and link each SSID to the corresponding subnet or VLAN and on each SSID or VLAN linked to the required encryption method.
Fbarboza:
We had a discussion before somewhere in this forum about the difference between wpa-tkip\wpa-aes and wpa2-tkip/wpa2-aes in wireless controller config. The conclusion was that with wpa2 the RSN IE is exist while this IE is not exist with wpa regardless of what encryption (tkip or aes) is usd.
The question would be here why this is not aplable here with the autonomous APs? I expected wpa-aes to work fine with 1140 ap although 802.11n is not supported?
More, do you mean that with mbssid/vlans the wpa-aes will be configured without a problem on the AP?
Rating useful replies is more useful than saying "Thank you"
Bronze
WPA version 1 uses the encryption cipher of TKIP and WPA version 2 uses the cipher of AES as per compliance with the IEEE.
To use AES-CCM on the unit just change the encryption method of WPA version 1 to version 2 and then change the cipher to AES-CCM.
The option of using multiple SSIDs what it does is allow you to use an encryption method on one SSID and a different encryption method on a different SSID.
In either case working with one SSID or working with several SSIDs if you want to use AES-CCM as the cipher than you will need to use WPA version 2.
Now if you want to leave WPA version 1 configured and use AES-CCM then you can configure AES-CCM + TKIP and this may or may not work depending on the wireless clients if it supprots it.
The command you will need to use is "encryption mode ciphers aes-ccm tkip " under the radio interface globaly if working with one SSID or under the specific VLAN if working with VLANs.
"encryption vlan 998 encryption mode ciphers aes-ccm tkip "
Hi.
Thank you. This was my understanding.
But the question is: with wlc you can configure wpa2-tkip only (without enabling wpa2-aes), why this is not applicable to autonomous APs?
I am aware about client issues in such situation but as it can be done onwlc why not on standalone ap?
Amjad
Bronze
The WLC is not IOS based vrs the AP in stand alone mode that it is.
The WLC allows us to connfigure different options this would be more a develper question thar way the IOS software allows it and the WLC software not.
I just run a check and configured an 1140 access point and was able to configure the GUI to use WPA version 1, with AES-CCMP
dot11 ssid TEST
   authentication open
   wpa-psk ascii 7 070C285F4D06485744465E
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
since you have VLANs configured on the AP checking on the configuration of the AP, remove the command
encryption mode ciphers aes-ccm tkip using the command no encryption mode ciphers aes-ccm tkip and then just try
Thank You fbarboza for the answer.
I tried your configuration, but when I tried to turn on the SSID with this command:
interface dot11radio 0
ssid TEST
The error "AES-CCMP Cipher is not supported with WPA Version 1" showed up again.
Do I have to use WLC and lightweight AP to get what I want? I really hope there are others possibilities that I can do with my autonomous AP
Hall of Fame Super Silver
What code were you running fbarboza? Maybe you need to run the same code in order to do what you want.
-Scott
Bronze
The code that the test access point I used is 12.4(21a)JA1 and i configured it via the GUI.
I will try later to configure it over the CLI and see if I get the error message.
Bronze
I just configured an access point via the CLI which has no VLANs or different SSIDs set just one SSID known as test and using the encryption command on the config t of the global interface and got no errors at all.
User Access Verification
Username: Cisco
Password:
AP1142AG.246>ena
Password:
AP1142AG.246#
AP1142AG.246#config t
Enter configuration commands, one per line. End with CNTL/Z.
AP1142AG.246(config)#dot11 ssid TEST
AP1142AG.246(config-ssid)#
AP1142AG.246(config-ssid)#authentication open
AP1142AG.246(config-ssid)#authentication key-man
AP1142AG.246(config-ssid)#authentication key-management wpa version 1
AP1142AG.246(config-ssid)#wpa-psk
AP1142AG.246(config-ssid)#wpa-psk as
AP1142AG.246(config-ssid)#wpa-psk ascii 7 070C285F4D06485744465E
AP1142AG.246(config-ssid)#exit
AP1142AG.246(config)#exit
AP1142AG.246(config)#int dot11 rad
AP1142AG.246(config)#int dot11ra
AP1142AG.246(config)#int dot11radio 0
AP1142AG.246(config-if)#encryption mode ciphers aes-ccm
AP1142AG.246(config-if)#exit
AP1142AG.246#
show run:
AP1142AG.246#show run
Building configuration...
Current configuration : 1522 bytes
version 12.4
no service pad
service password-encryption
hostname AP1142AG.246
enable secret 5 $1$svcK$heK3ptEJ/Aj3ISsXnpll9.
no aaa new-model
dot11 syslog
dot11 ssid TEST
   authentication open
username Cisco password 7 032752180500
bridge irb
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
AP1142AG.246#
Are you configuring the unit via the CLI or GUI once you get the error message?
thank you all of you, for your respond..
Username: Cisco
Password:
AP1142AG.246>ena
Password:
AP1142AG.246#
AP1142AG.246#
show run:
version 12.4
no service pad
no aaa new-model
dot11 syslog
dot11 ssid TEST
   authentication open
bridge irb
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
AP1142AG.246#
fbarboza, I just see your configuration and I wonder if the ssid TEST will show on your computer without this command:
ssid TEST
I have copied your configuration immediately, and the ssid didn't show up on my PC. When I type this comment,
ssid TEST
I immediately got an error like usual. "AES-CCMP Cipher is not supported with WPA Version 1"
In response to your question before, yes, I used CLI and got that error. I also tried using GUI, but as a result, the cypher didn't change, still in tkip mode.
Thank You before.
3503
