AIR-1252 Antennas required?
Just purchased 2 AIR-LAP-1252AG-A-KP APS. I notice it has external Antenna Connectors. I have loked in the Doc but can;t find the info I am looking for. I want to use them inside a gym and was wondering if they will work without external antennas.
Mike
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: AIR-1252 Antennas required?
Hi Mike,
The 1252 does not have "built-in" Antenna/Antennas options, so external Antennas are required;
Supported Antennas are listed in this doc;
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c1.html
Have a look at this good thread which includes some good insight on Antenna options, from Dennis, who is very knowledgable about 11n;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddfd891
Hope this helps!
Rob
Hall of Fame Super Gold
Hi Mike,
Antenna Product Portfolio for Cisco Aironet 1250 Series Access Points
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
Avoid running the AP's without any antennaes or you might permanently damage the transceiver.
Hope this helps.
Hi Mike,
Hope this helps!
Rob
Rob,
Thanks for the info. That really cleared it up me.
Mike
Hi Mike,
Hope this helps.
SUper,
Thanks so much. Looking at the different radiation patterns really helps when figuring out which antenna I need.
Thank you.
Mike
Thanks for the ratings, Mike.
463
