AIR-ANT2588P3M-N Deployment on a Mobile trailer
We are installing 3x 2.4-GHz/5-GHz 8-dBi Directional Antenna (AIR-ANT2588P3M-N) in an inline configuration on a mobile trailer for a mining site.  Currently, I am designing the head frame for the antennas and need some input on how far apart the antennas (horizontal spacing) should be placed.
The plan is part a mobile AP deployment with the 1552E and EU.  I am not the network designer.  In this case, I have been asked to work on the mount design.  So, I am working with what I know, which is what is stated above.
Hall of Fame Super Gold
Three of these per AP?  What
Three of these per AP?  What for?
This antenna has three antenna "ports".  The only AP that can use this is the 1602E.  So one antenna can plug directly to a 1602E.
Karschnik,  you only need 1
Karschnik,  you only need 1 AIR-ANT2588P3M-N per AP, not 3 for the 1552E.  Your 1552EU's need one each 2g and 5g antenna.
and all your hard work was already done by Cisco, just buy the mounting kits.
Leo,  My first thought also, but this flavor has N connectors to the 1602e's rptnc's.
This antenna is listed in the current 1520 series buyers guide. for the 1552E
The 1552EU needs 1 ea AIR-ANT2413P2M-N and AIR-ANT5114P2M-N
Dont forget the AIR-ACCPMK1550 pole mount and the
AIR-ACCAMK-1 directional Antenna Mount Kit.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1550/quick/guide/1550antbracket.pdf
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1550-series/data_sheet_c78-719520.pdf
However, the EU version of the 1552 has 2 sets of 3 single band antenna ports, where the E has 1 set of 3 dual band ports.
83
