AIR-AP 1131AG-E-K9 cannot Join on Virtual WLC
I have an AIR-AP 1131AG-E-K9  an was trying to register it to vWLC.
  • Cisco Aironet 1131AG Version : 12.4
  • vWLC on Vmware Workstation Version : 7.4.121.0
These logs are showing on my AP:
*Jul 14 17:41:13.344: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jul 14 17:41:13.344: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jul 14 17:41:13.344: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jul 14 17:41:13.344: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 192.168.8.2
*Jul 14 17:41:13.554: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.8.2
*Jul 14 17:41:13.554: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.8.2:5246
*Jul 14 17:41:13.616: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jul 14 17:41:13.639: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jul 14 17:41:13.639: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jul 14 17:41:13.640: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 14 17:41:13.712: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 14 17:41:14.638: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jul 14 17:41:14.671: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jul 14 17:41:14.676: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul 14 17:41:15.665: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jul 14 17:41:15.670: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jul 14 17:41:15.700: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 14 17:41:15.705: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jul 14 17:41:15.710: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jul 14 17:41:16.700: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jul 14 17:41:16.705: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jul 14 17:41:16.729: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 14 17:41:17.729: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jul 14 17:41:23.711: %CAPWAP-3-ERRORLOG: Go join a capwap controller % Be sure to ask the CA administrator to revoke your certificates.
VIP Purple
Can you paste the output of
Can you paste the output of these commands:
From WLC: sh sysinfo
From AP: sh evrsion
I think you have tried to factory reset the AP already, if not, try it. Also, try the following commands 'test capwap erase' 'test capwap restart'
Dont forget to rate helpful posts
(Cisco Controller) >show
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.121.0
RTOS Version..................................... 7.4.121.0
Bootloader Version............................... 7.4.121.0
Emergency Image Version.......................... 7.4.121.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.8.2
System Up Time................................... 0 days 2 hrs 15 mins 17 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 00:0C:29:CF:F1:98
Maximum number of APs supported.................. 200
APc471.feb0.9f70#show version
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(25e)JAM3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 03:11 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
APc471.feb0.9f70 uptime is 4 minutes
System image file is "flash:/c1130-k9w8-mx.124-25e.JAM3/c1130-k9w8-mx.124-25e.JAM3"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-E-K9    (PowerPCElvis) processor (revision B0) with 27638K/5120K bytes of memory.
Processor board ID FCZ1452Q0WZ
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.4.121.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:71:FE:B0:9F:70
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC14481C8F
Top Assembly Part Number             : 800-29230-02
Top Assembly Serial Number           : FCZ1452Q0WZ
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1131AG-E-K9
Configuration register is 0xF
VIP Purple
Hi,Your AP Model is : AIR
Your AP Model is : AIR-AP1131AG-E-K9   (This is for Europe Domain)
 and your WLC Configured for America Domain:
1. If you are in US then your AP must have -A-domain.(Like: AIR-AP1131AG-A-K9)
or
2. if your are in somewhere in euope then your WLC must be configured for different Country(Europian) code.
321
