AIR-AP-1231 for guest access
I have a requirement to provide wireless access to a group of devices. Iphones/netbooks etc. I have an ADSL wired connection and an AIR-AP-1231.
I have connected the AIR-AP-1231 to the ADSL router and have got an IP and have got onto the management page but I cannot get the wireless network to be seen.
I also need to restrict access to only specific MAC addresses. Longer term I want to roll out more AP's and connect them with a controller.
I need to find a basic starting guide and want to know if the AP-1231 is suitabel for this role or should I be looking at using a standard Linksys type wireless router?
1 ACCEPTED SOLUTION
Silver
Re: AIR-AP-1231 for guest access
You have a ciphers setting on vlan 1 under your d0 interface. That's the start of a WPA solution but you need more under the SSID config:
dot11ssid Cisco
authen key-management wpa version 2
wpa-psk ascii MySuperSecretKey
To get MAC filtering working, use the following example. Substiture in appropriate mac addresses for the X's; leave the 0's unchanged.
access-list 700 permit xxxx.xxxx.xxxx 0000.0000.0000
dot11 association mac-list 700
Silver
The AP1231 will certainly do what you want, although if you're not already familiar with the product then it may be easier with a consumer product.
If you paste the config from your AP here, we can post the edits you'll need to make.
Thanks, I would like to stick with the AP as I am planning on installing a lot more over the next few months.
I managed to get the wireless up (had to enable the interface!)
I then managed to connect and route over the ADSL (set vlan1)
I have now managed to lock my self out with the WPA settings and would like to find out how to permit only specified MAC addresses to be able to associate with the AP.
Roger
sh
% Type "show ?" for a list of subcommands
ap#sh run
Building configuration...
Current configuration : 1511 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$DyN2$qtAcjiul5LkmkPjbguagb.
ip subnet-zero
no aaa new-model
dot11 ssid Cisco
vlan 1
authentication open
guest-mode
dot11 network-map
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
ssid Cisco
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root access-point
antenna gain 128
world-mode dot11d country GB indoor
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Silver
dot11ssid Cisco
Perfect - all working as I wanted to now.
Many Thanks
Roger
607
