AIR-AP1131AG-E-K9 has no web interface
suzanneaardema
Hi.  I am attemting to configure a Cisco Aironet 1130AG series access point (AIR-AP1131AG-E-K9) and after I reset the AP, I cannot access the web interface.  When I enter the IP address in Internet Explorer I receive the following page after entering the default password:
  When I click on Web Consile, I receive the following page:
This in in Dutch because the laptop I am using to configure the AP has a Dutch Operating System.  However, it is the standard IE page that says that the requested web page cannot be found.
I have configured several of these AP's and this is the first time I have hot been able to access the web console.
Here is the Tech Support information:
Can you please advise me as to how I can access the Web Console for this access point?
Kind regards,
Suzanne
10 Replies 10
paolo bevilacqua
Wrong forum, post in "Wireless". You can move your posting with the Actions panel on the right.
Scott Fella
You need to console into the ap and then makes sure there is a command in the configuration for: ip http server
On the console issue a:
show run-config
-Scott
Hi Scott,
I am not sure how to do what you are suggesting given the options that I have:
Can you please be more specific?
Suzanne
Here are instructions on how to console into an ap.
https://supportforums.cisco.com/docs/DOC-2320
-Scott
Hi Scott,
The AP1131AG does not have a serial port.  According to these instructions, http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c4.html#wp1085302
I need a nine-pin, female DB-9 to RJ-45 serial cable which I do not have...
I also cannot download the required software because I do not have a service contract!!
http://software.cisco.com/download/release.html?mdfid=279537722&reltype=latest&relind=AVAILABLE&dwnld=true&softwareid=284180979&rellife
Do you have any other suggestions as to how I can communicate with this access point?
Many thanks,
Suzanne
Well your really out of luck here.  Console access is the best way to actually configure the AP or at least make some changes.  Not having a service contract so you can download the image is another set back as that would be your next step.  I would just try to reset the AP back to factory and see if it works:
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c3.html#wp1036746
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
I put this project on the side for several months and now I have made a bit more progress.  I was able to upgrade the firmware to c1130-k9w8-tar.124-25e.JAO5.tar and that went perfectly.
However, I have absolutely no web console now.  The ip http server is set to no, and I do not have an available command to turn it on.  I have tried downgrading the firmware, but that times out.  Please see the attached listing from the hyperterminal session.
The commands I have available to me are as follows:
AP0018.b9f9.8aa0#?
Exec commands:
  capwap           capwap exec commands
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  dot1x            IEEE 802.1X Exec Commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapconfig       OfficeExtend AP configurations
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  radius           radius exec commands
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  rsh              Execute a remote command
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  ssh              Open a secure shell client connection
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
I just spent a couple of days working to get it this far, so any advice you can give me would be appreciated.  I want to be able to access the AP via the web interface using the specific ip address which was assigned by the DHCP server.
Many thanks,
Suzanne
I finally got this sorted out.  I had the IP address on my laptop set to 10.0.0.1, and when I tried to load new firmware it constantly timed out regardless of what I did.  When I changed the IP address to 10.0.0.2, it worked perfectly.
Here is the procedure to load new firmware:
Step 1 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifThe PC you intend to use must be configured with a static IP address in the range of 10.0.0.2 to 10.0.0.30.
Step 2 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifPlace a copy of the access point image file (such as c1130-k9w7-tar.123-8.JA.tar) into the TFTP server folder on your PC. For additional information, refer to the"Obtaining the Access Point Image File" and "Obtaining the TFTP Server Software" sections.
Step 3 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifRename the access point image file in the TFTP server folder to c1130-k9w7-tar.default.
Step 4 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifActivate the TFTP server.
Step 5 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifIf using in-line power, use a Category 5 (CAT5) Ethernet cable to connect your PC to the To Network Ethernet connector on the power injector.
Step 6 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifOpen the access point cover (refer to the "Opening the Access Point Cover" section).
Step 7 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifDisconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 8 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifPress and hold the MODE button while you reconnect power to the access point.
Step 9 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifHold the MODE button until the Radio LED turns a red color (approximately 20 to 30 seconds), and release the MODE button.
Step 10 http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifAfter the access point reboots, you must reconfigure the access point by using the Web interface, the Telnet interface, or Cisco IOS commands.
I've tried the same, but no luck, still getting timeout and there is no startup-config either available on the AP.
Any help please ...
The reason why you can't get into the web interface is because someone has loaded the IOS by copying the BIN file into the AP.
When you copy only the BIN file, the web interface materials are MISSING.
If the web interface sub-directory is present then the BIN file is stored in the root directory and doesn't know WHERE the HTML sub-directory is located.
