Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
AIR-AP1142N-E-K9 ethernet interface stops working
I installed two AIR-AP1142N-E-K9 access points, running a fairly simple config, WPA2 PSK, with AES cipher, both the same SSID.
The two access points are connected to Cisco 2960G switches, which are in turn connected to each other, again without any fancy config options, no VLAN's ed.
After a random while, varying from 30 minutes to 15 hours, the access points will stop sending/recieving traffic on the ethernet interface.
The units don't stop at the same moment, this also varies seemingly random. It's not related to load or the amount of clients (1 to 15).
Only turning on one unit doesn't make any difference.
The units keep sending out their SSID, you can associate to them, but the DHCP requests aren't passed on to the DHCP server which is connected to one of the 2960G's.
If you wirelessly connect to the AP and set a manual IP adress you can reach the webinterface and telnet/ssh to the access point. The ethernet link is reported as being up on the access point. Also the switch reports a link on the port to which the access point is connected.
Resetting the link does have no effect.
The log doesn't mention any errors or warnings.
Power cycling or reloading the access point will put it back in working order for a varying amount of time.
Access point version:
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Access point config:
! Last configuration change at 14:41:40 +0100 Sat May 12 2012 by admin
! NVRAM config last updated at 14:41:40 +0100 Sat May 12 2012 by admin
version 12.4
no service pad
service password-encryption
hostname AP2
enable secret 5 XXXXXXXXXXXX
no aaa new-model
clock timezone +0100 1
ip name-server X.X.X.X
dot11 syslog
dot11 ssid XXXXXXXXXX
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 XXXXXXXXXXX
username admin password 7 XXXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid XXXXXXXXXX
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid XXXXXXXXXX
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address X.X.X.X X.X.X.X
no ip route-cache
ip default-gateway X.X.X.X
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community public RO
bridge 1 route ip
line con 0
line vty 0 4
login local
sntp server 194.109.22.18
sntp broadcast client
end
Has anyone ever encountered this? Or even better, knows the solution?
There are a lot of reasons behind that.
In the meantime please attach the following
Show tech from one defected AP
Show tech from the switch at which the AP is connected
highlight the port at which the AP is connected
Re: AIR-AP1142N-E-K9 ethernet interface stops working
Attached are the "show tech" outputs from one of the AP's and the switch it's connected to.
The AP is connected to port GigE 0/21 of the switch.
Hello Fabio
can u upload the show log from the AP
Also try to run the following command from time time till the issue happens:
show proc memory sorted
to see if there is certain process smoking the memory on the AP
Show log just after a reset after the unit stopped responding.
Show proc memory sorted just before it stopped responding.
Hall of Fame Super Gold
Hmmmm ... 2960G so which means you could be powering the WAPs using a Power Injector.
Can I ask for the following output:
1.  2960G:  sh interface ;
2.  2960G:  sh log
3.  2960G:  sh controller e ;
These outputs are available in the show tech
The units are powered by AIR-PWR-B= dedicated power supplies.
Hello Fabio
Here is what should be done for the time being to narrow down the root cause:
ollect the output of the following commands every 30 minutes period for one of the APs
that are facing the problem till the issue happens again.
Show memory statistics
Show logs
Send me the outputs collected on multiple stages
When the issue happens we need to collect sniffer trace while the client is not able to get
an ip address on the switch port at which the AP is connected to verify if the AP actually blocking
the DHCP traffic or not.
I have upgraded one of the units to 12.4(25d)JA1 this morning, waiting to see if the problem will occur with this firmware version as well. Just to clarify, it's not just DHCP that isn't getting through, the whole ethernet link seems dead when it happens, no traffic at all.
COOOOL!
Try this commands on the switch:
1.  Command:  test cable tdr int g0/21;
2.  Wait for approximately 7 seconds;
3.  Command:  sh cable tdr int g0/21; and
4.  Please post the output.
Both AP's have been running all day now with 12.4(25d)JA1, with a moderate load, 5-15 clients, mixed 2.4 and 5 Ghz.
No problems so far.
I think that proves there is nothing wrong with the cables or the switch and the problem lies within the factory installed 12.4(21a)JA1 firmware.
Imo a bad thing "enterprise" units are shipped out with a firmware version not even able to perform a completely basic setup.
Did you also upgrade the bootstrap to version 12.4(23c)JA1?
No, didn't touch the bootstrap.
Should I upgrade the bootstrap as well?
Units are still running btw.
1440
