Community Member
AIR-AP1220B Series - Boot Fail
I have the above system and when it boots the lights are as follows, top - off, middle - Solid RED, Bottom - Solid Yellow.
If I attach a console cable and power on i get the following
Testing DRAM...
(press <esc> to bypass)
***> DRAM Error!
00000104: 00000000 -> E0330832
00000108: 00000000 -> FFFFFFFF
00000104: FFFFFFFF -> E0330832
I have another unit with ALL lights on Solid Yellow, and with no console info.
Are the units beyond repair.
1 REPLY
Silver
Re: AIR-AP1220B Series - Boot Fail
This might indicate a corrupt image. Reset the access point and try again. If this doesnt work you can reload the IOS image using CLI section in the following URL http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1038660
153
