Community Member
Air-AP1220B series
I am trying to set up this 1220B AP so I can browse to its configuration screen however I can't establish a connection even though I believe I have the AP and my PC configured correctly. Here are the settings:
AP Settings
IP 10.0.0.1 SN 255.255.255.224 manually set
PC directly connected to the AP through the ethernet port (cable confirmed to be good):
IP 10.0.0.2 SN 255.255.255.224
Even with these settings and a direct ethernet cable connection I cannot even Ping the AP.
I did a show run and the configuration is correct. The ip http server is enabled.
Any suggestions would be appreciated.
Hall of Fame Super Red
Re: Air-AP1220B series
Hi Robert,
Can you please try a cross-over cable. I remember some of the AP's require this.
Hope this helps!
Rob
Silver
Yup, 1220s definitely require a cross-over.
Green
The AP's IP address goes on the BVI interface, not the Ethernet interface.
Make sure you are plugging into the Ethernet port, not the console port ... both are RJ-45 and side-by-side ... easy to miss one for the other.
Check your software firewall for correct permissions.
Check your speed/duplex settings and/or plug both into a switch.
Plug into the console and see what messages are popping up when you plug the Ethernet cable in.
The crossover cable suggestions are probably your best start.
Good Luck
Scott
358
