AIR-AP1242AG-A-K9 remote site flexconnect mode Association Problems
Hi everyone,
I have a remote site with 2 access points AIR-AP1242AG-A-K9, they are registered to a WLC 5508 version 7.4.110.0, the issue that I have is every 20 min the AP's lost registration to the WLC, this is the log from the access point:
AP-Problem#
AP-Problem#
AP-Problem#terminal monitor
AP-Problem#
 %DTLS-5-SEND_ALERT: Send FATAL : Decode error Alert to xx.xx.xx.xx:5246
 %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to xx.xx.xx.xx:5246
 %WIDS-6-DISABLED: IDS Signature is removed and disabled.
 %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
 Starting Ethernet promiscuous mode
 %CAPWAP-3-ERRORLOG: Selected MWAR 'xx.xx.xx.xx'(index 0).
 %CAPWAP-3-ERRORLOG: Go join a capwap controller
 %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: xx.xx.xx.xx peer_port: 5246
 %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: xx.xx.xx.xx peer_port: 5246
 %CAPWAP-5-SENDJOIN: sending Join Request to xx.xx.xx.xx
 %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
 %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller GTGCWLAN
 %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
 %LWAPP-4-CLIENTEVENTLOG: SSID xx.xx.xx.xx added to the slot[0]
 %LWAPP-4-CLIENTEVENTLOG: SSID xx.xx.xx.xx added to the slot[1]
 %WIDS-6-ENABLED: IDS Signature is loaded and enabled
 %CAPWAP-3-ERRORLOG: Unencrypted non-discovery CAPWAP Control Message from xx.xx.xx.xx
 %CAPWAP-3-ERRORLOG: Invalid AC Message Type 1074106374.
 %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
 %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from xx.xx.xx.xx
 %CAPWAP-3-ERRORLOG: Invalid packet type 7.
AP-Problem#
AP-Problem#
AP-Problem#
I'll be waiting for your comments.
Alberto B.
HelloI have a very similar
Hello
I have a very similar problem with 1142 Access Points connecting back to a central FlexConnect Controller.
The WLC is running version 7.6.100.0
We see the same errors in our logs and debugs on the access points.
We notice that the controller association time is always resetting so the AP only joins for a matter of minutes.
Did you every find a resolution to this problem?
Thank you
Greg
Hi,In fact what we found was
In fact what we found was a network connection issue that was causing the problem, check the firewalls and also the WAN metrics.
Alberto B.
615
