Community Member
AIR-AP1242AG-a-K9
OK I have a AIR-laP1242AG-a-K9 but I have now down graded it to a AIR-AP1242AG-a-K9. But the problem am having. Is when I login to the administration panel and edit anything and then click the apply button nothing happen and it dose not. Save to the AP so does anyone have any ideas in where am going wrong
May I know the reason why you
May I know the reason why you down graded? Is other function of AP is workimg fine?
Community Member
The reason why you down
The reason why you down graded. Is am using. As a Ap in my Home and dont have a wireless controler And no not all things or working when I edit anything. And the try and apply the changes they don't apply to the AP. Its like the apply button don't work
VIP Purple
Hi,I think you want to set AP
I think you want to set AP as Repeater/Bridge.
There are porblems but not always with GUI. Its alwayas good to configure Autonomous AP via CLI this is the best way.
If you need the config guide, check this:
http://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
any more question then please write here.
Dont forget to rate helpful posts
Community Member
hi, now i have a problem with
hi,
now i have a problem : cannot show all clients by mac add and ip access  my AP 1242 AG-A-K9 .
Can you help me how to config by web interfaces , please email for me that hoaithanhdo@gmail.com or thanh.do@samsung.com
thanks so much !
Community Member
right i have found out why it
right i have found out why it was not working it was the web interface i was using but now i have a new problem and this is what i get when i try and set it as a Repeater after i have use the Express Security page to create unique SSID as it says in the Configuration Guide and saved it i then try to set it as a Repeater and get
Message from webpage
ERROR:
'Set Infrastructure SSID' must be configured in order to set the 'Role in Radio Network' to the following roles:
- 'Repeater'
- 'Access Point(Fallback to Repeater)'
- 'Non-Root Bridge'
- 'Non-Root Bridge with Wireless Clients'
(See Security>SSID Manager page).
any help please
Bronze
Please refer:http://www.cisco
Please refer:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68005-wlan-connect.html#conf1
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-3_7_JA/configuration/guide/i1237sc/s37frst.html#wp1121933
458
