AIR-AP1242AG-EK9 keeps rebooting
I there.
I have a problem with an AIR-AP1242AG-EK9 access point. I start the access point and after a short while it reboots by itself, this keeps appening and the time that it takes to reboot isn´t always the same. I´ve tried different IOS versions and the outcome was always the same.
When it reboots i can se some processing errors or something like that.
Does anyone as any idea why this keeps happening?? Does anyone know how to fix this???
Is this a hardware problem??
Thanks in advanced.
Miguel Santos
I get this errors when i simply try the command flash_init
ap: flash_init
Initializing Flash...
flashfs[0]: found corrupted block[2] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[4] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[6] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[10] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[12] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[14] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[16] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[18] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[20] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[22] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[24] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[26] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[28] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[30] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[37] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[40] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[44] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[46] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[48] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[50] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[54] (byte 504, sector 251), fixing...
-- MORE --
flashfs[0]: found corrupted block[56] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[58] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[62] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[66] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[70] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[72] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[74] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[88] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[90] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[92] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[98] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[101] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[114] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[118] (byte 504, sector 251), fixing...
flashfs[0]: found corrupted block[123] (byte 504, sector 251), fixing...
flashfs[0]: Trying to read a sector from block 73, with an invalid sector number!!!
Re: AIR-AP1242AG-EK9 keeps rebooting
I get this crash info file, that i´ve atached where, after the AP reboots.
Thanks again
Miguel Santos
Looks to be something corrupt with the flash, may you can try to format flash and load the image
NikhiL
Thanks for the quick reply.
I´ve tried that already. I´ve tried formatting it and then loading different images but result was the same.
Thanks again.
Miguel Santos
Hi Miguel,
Please get this AP RMA. Bad flash.
Thanks..Salil
795
