12-15-2011 12:12 PM - edited 07-03-2021 09:15 PM
We are upgrading the way we update our inventory by using handheld scanners running windows mobile 6. The company supplying these suggested we use the AIR-AP1262N-A-K9 access point for the area that these handhelds are used in. I've setup tons of access points before, including the existing ones in this building. I found the interface of this access point to be a little overkill, but thats beside the point. Basically i've set this access point up to broadcast the ssid and require an ASCII wpa password to join the network for security, really basic. laptops and these handhelds can connect to it, but after 10 minutes the connection is lost. It will continue to connect and reconnect constantly instead of just keeping the connection. The strength is fine, literally within 10ft of the access point. I was wondering if someone could either tell me whats going on or possible give me a simple configuration that i can use to give me simple broadcasted ssid with a WPA password? thanks.
Solved! Go to Solution.
12-15-2011 12:44 PM
1. Not all hand-helds like passwords. Try OPEN authentication first.
2. Have you tried enabling the lower rates of the 802.11b radio?
3. Can you also try this command in both of your radios? Command: no dot11 extension aironet
12-15-2011 12:42 PM
Scott,
Does a laptop have the same issue, or is it just the handhelds? It's possible that the driver version on the handheld is a rev or two (or three) back from the current. If it is, updating the driver and test, would be my first step in troubleshooting.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
12-15-2011 12:45 PM
Laptop does it, smart phones do it. Doesn’t seem to matter what it is, it just won’t lock the connection.
12-15-2011 12:44 PM
12-15-2011 12:47 PM
I’ve actually tried that with the same result, and it’s also not limited to the handhelds, laptops, smart phones, etc. all do the same thing, the connection won’t stay locked. I have the AP set to throughput, which enables the entire radio range, are you suggesting I limit the range to the lower ones only?
12-15-2011 12:49 PM
Also,im using the web interface. Im not real familiar with Cisco, so I honestly don't even know how to access the CLI to input that command. is there a way to do it in the web interface? I apologize for my Cisco ignorance.
12-15-2011 01:04 PM
12-16-2011 06:07 AM
Turning off Aironet extensions worked. thanks everyone.
