AIR-BR1310G-A-K9-R WiFI Encryption Configuration
Aironet Model:  AIR-BR1310G-A-K9-R
IOS: Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
Hello:
     I have inherited a WLAN with three AIR-BR1310G-A-K9-R routersconfigured as APs and two other APs
from a different mfg in the same WI-FI HotSpot.  The three Cisco APs have been set to WEP encryption
while the two non-Cisco were set to WPA2-Personal.  There appears to be no particular reason for the WEP-
vs-WPA2 encryption differences other than it is the default for both, apparently.
My question here is, what encryption types does the Aironet 1300 Series support, is it only WEP?   I
would like to have more options than just WEP for the BR1310s, is that possible?   When I log into the
Cisco router's HTML page and look at encryption it only show WEP as an option.  I have been told that there is a later
version of the IOS, Autonomous AP IOS Software-12.4.25d-JA2, does it offer WPA or above encryption?
Thanks in advance for your time and consideration.
Doug
3 ACCEPTED SOLUTIONS
with Cisco IOS Software Release 12.2(15)JA for 1300 it supports WPA version 1 with TKIP.
Link attached:-
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_bulletin09186a00802134a9.html
VIP Purple
With 12.4.25d-JA2 IOS you can configure WPA2/AES on 1310 as well. I had a 1310 AP model & I configured & verified.
Here is the basic config involved.(I have simply configured DHCP on AP it self & you can change it in your case)
1310-1#sh ver
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(25d)JA, RELEASE SOFTWARE (fc1)
ip dhcp excluded-address 192.168.178.1 192.168.178.50
ip dhcp pool TEST
   network 192.168.178.0 255.255.255.0
   default-router 192.168.178.1
dot11 ssid TEST
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii Cisco123
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid TEST
interface BVI1
ip address 192.168.178.1 255.255.255.0
%DOT11-6-ASSOC: Interface Dot11Radio0, Station   04f7.e4ea.5b66 Associated KEY_MGMT[WPAv2 PSK]
Here is the config guide for this IOS release
http://www.cisco.com/en/US/customer/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/cg_12_4_25d_JA.html
Rasika
**** Pls rate all useful responses ****
VIP Purple
Hi Doug,
You can configure WPA2/AES with PSK (Pre-Shared Key) without a RADIUS server. If you want to configure WPA2/AES with 802.1X then only you require a RADIUS server.
Regarding monitoring, you can try SNMP  monitoring with Solarwinds (you should be able to do a test with their free trial version) & see whether you can extract that information.
In cisco AP CLI, you can try "show dot11 association" & "show dot11 association " to get more details about client connection.
Rasika
Hall of Fame Super Silver
Re: AIR-BR1310G-A-K9-R WiFI Encryption Configuration
I don't think they will support WPA2, but with v12.4, you will be able to use WPAv1/TKIP.
-Scott
Hi Scott
     Thank you for responding and for doing it so quickly.  That does not appear to be an option under my current IOS, Cisco IOS C1310 Software (C1310-K9W7-M), Version 12.4(10b)JA, RELEASE SOFTWARE (fc2), unless I am missing something.  Is it an option under AP IOS Software-12.4.25d-JA2?   Is there detailed documentation available for AP IOS Software-12.4.25d-JA2 or some other version?   I have no idea how much it will cost to upgrade the IOS but I want to be sure before I spend the money. :-)
Doug
I agree with Scott, you should be able to WPAv1/TKIP with the code you are running.
you should be able to go to the CLI
dot11 ssid < what it is>
authenticaiton open
authentication key wpa
wpa-psk ascii 0 < your key >
infrastructure-ssid optional
then under the radion
dot11Radio0
encryption mode ciphers tkip
if you are calling a vlan in the SSID config then you would need to do vlan < blah > encryption mode ciphers tkip
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hi Scott
      One additional consideration, the two non-Cisco APs in at this site give the User the option of selecting WEP, WPA,  & WPA2/Personal.  What I am hoping to do is to get away from WEP and get as many users as I can up to WPA2 or above.
Doug
VIP Purple
1310-1#sh ver
ip dhcp pool TEST
dot11 ssid TEST
   authentication open
   guest-mode
ssid TEST
interface BVI1
Rasika
Hi Rasika
    Thank you so much for the help!   I ran into a problem when i tried to access the IOS link in your response, "
http://www.cisco.com/en/US/customer/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/cg_12_4_25d_JA.html", it take me to the following URL with this error message: http://www.cisco.com/msgs/403.html
Forbidden File or Application
    At that point I can go no farther, so I have been unable to see the document.
VIP Purple
,Hi Doug
Try this link, it should work for you
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/cg_12_4_25d_JA.html
Rasika
Hi Rasika
    When you set the security to WPA2/AES  were you using a Radius server?  I am not using Radius. In my configuration I am using 5 APs (three of which are Cisco AIR-BR1310G-A-K9-R APs and the other two are non-Cisco APs, Authentication is handled locally by each AP.  When I look at the IOS instruction and at the 1310's html admin pages it looks like WPA only works with Radius, but I did not get impression from your response above. I am hoping that this can be done without Radius.
   BTW -  I would like to find an app to use the WLAN or at least with the Cisco APs that would show me data such user Mac, connection type (802.11(a) or (b) or (g),  etc...for each AP.  I am not sure what information logging actually collects and it;s not real time, which would be nice to have.  I also don't know what the overhead and impact of logging is on this Aironet Model, do you?
Thanks!
Doug
VIP Purple
Hi Doug,
Rasika
Thanks!
Link attached:-
1292
